woodsy144
posted on 5/1/25 at 10:06 AM |
Need help ID'ing steering tie rod arm
Hello all.
I am helping a club member who is not confident with computers.
He has what he believes is a Robin Hood, and it appears that one of the tie rod ends is stuffed. So if we can get some help it would be great. I also
think that the part has been machined with a new course thread put on it. So can you please:
- id the front suspension layout (I think it is Ford sierra)
- id the steering rack
- offer guidance on a replacement part
Thank you all
https://flic.kr/p/2qDHikM
https://flic.kr/p/2qDF6UW
https://flic.kr/p/2qDHiiN
https://flic.kr/p/2qDHiis
https://flic.kr/p/2qDAvG1
https://flic.kr/p/2qDGojq
https://flic.kr/p/2qDAvKn
https://flic.kr/p/2qDGoiy
SteveWalker
posted on 5/1/25 at 02:11 PM |
Likely Sierra or Escort rack, with a Transit drag link on the end.
adithorp
posted on 5/1/25 at 02:37 PM |
1. Sierra hub.
2. Sierra steering rack.
3. Not sure. It's nota transit drag link end as they're not offset and the tread is male,where that one is female. Ut could be Sierra as the
lower arm is also Sierra.
Generally though, that's a track rod end. A tie rod is more usually a fixed rod controlling rear hub toe (unless you're in US) or holding a
lower arm in the same way the ARB is in that Sierra setup.
The modification looks to be an extension of the track rod. You'll probably find the rack itself has been shortened in the middle. All about
getting the knuckle/inner joint in a better position for bump steer purposes.
http://jpsc.org.uk/forum/
SteveWalker
posted on 5/1/25 at 03:02 PM |
My mistake, I was remembering that mine used a Transit drag link, but that was for the top joint!
I've looked again and it does look like it could be a standard Sierra. https://www.ebay.co.uk/itm/133867330930?_skw looks like there is a slight
offset. I've just gone outside and looked under my cover and my RH Series 3 definitely has the offset to its Sierra joints.
Dingz
posted on 5/1/25 at 04:38 PM |
It’s a series 1 S7 with the Sierra front crossmember it will be a standard, (early?) Sierra rack and track rod ends. Unless someone’s had a go at it!
went on and on.
woodsy144
posted on 5/1/25 at 10:22 PM |
Thank you all for your help.
We believe the failure is in the drum stick tie rod ends, not the outer offset track rod ends.
Does anyone have some possible part numbers for these parts??
russbost
posted on 7/1/25 at 09:10 AM |
You need to get the track rod off the rack, looks like there are 2 types for Sierra, one with a small thread, one with a large thread
See Here
Or here
Alternative would be to pick up a SH complete steering rack, tho' they are becoming few & far between & no guarantee it would be any
better than what you have already
40inches
posted on 7/1/25 at 09:53 AM |
I used this one recently https://www.ebay.co.uk/itm/235660329465
