budha
posted on 12/3/25 at 09:20 PM |
Striker Live Axle Diff Removal
I have to rebuild my diff. Any change to get it out without removing the fuel tank? Is it worth giving it a try?
yogibear1969
posted on 13/3/25 at 11:58 AM |
When I changed mine on Striker it came forward, so the fuel tank wasn't an issue, it was a while ago so might be wrong but difinitely didn't
remove the fuel tank
Edd.
obfripper
posted on 13/3/25 at 06:27 PM |
I released the two lower trailing arm bolts on the axle and tilted the axle casing back so the diff nose was facing down at an angle, this gave enough
room to drop the diff out.
The fuel tank shouldn't be an issue unless you have a larger custom tank in there, the original mini van tank leaves plenty of room to work.
Dave
bi22le
posted on 13/3/25 at 08:43 PM |
This question will be answered TOMORROW. . . . Kind of!
A new episode is out tomorrow on https://www.youtube.com/@TeaNBizz-Kits where I race against the clock to remove my diff from my IRS striker.
Please take a look. Its an extended episode which covers some custom 3D printed parts, compression testing my engine and POR15.
Also subscribe and check out the other episodes. THANK YOU!!!
[Edited on 13/3/25 by bi22le]
Please read my ring story:
budha
posted on 13/3/25 at 09:21 PM |
Perfect, thanks guys! I will find out Saturday ;-)
yogibear1969
posted on 14/3/25 at 03:21 PM |
I suspect not...the OP has an English axle, not an IRS!
Edd
jacko
posted on 16/3/25 at 05:21 PM |
Well it’s Sunday is the diff out
G
555
budha
posted on 16/3/25 at 06:31 PM |
Yes, diff is out. What I learned:
- You need a slide hammer to pull the half shafts
- Fuel tank can stay
