Author: Subject: Ideas please - tiny trailer reversing
coyoteboy
posted on 29/4/25 at 12:37 PM Reply With Quote
So, I was kindly gifted a tiny ERDE 121, it's super handy for simple stuff like nipping to the tip. The big problem is I can't see it for toffee behind my Hilux. It's borderline jackknifed before it becomes visible. I've been looking to put vertical markers on the back corners so I can see out of the rear, and rather than having them out the side to save me catching them on stuff. However I can't find a low cost solution - most seem to be £30 LED lit antenna, snow plough blade markers which are made of steel wire and wrapped in rubber, but ultimately still 30 quid. Does the hive have any thoughts?
JAG
posted on 29/4/25 at 01:05 PM Reply With Quote
Cheap Whip Antenna
How about something like this? You could add a 'flag' to the tip made of Duct tape for a bit more visibility
Justin
loggyboy
posted on 29/4/25 at 01:31 PM Reply With Quote
Reverse camera? cheap as chips for basic one.
Mistral Motorsport
posted on 29/4/25 at 01:56 PM Reply With Quote
Same thought here, a reverse camera will solve your worries.
gremlin1234
posted on 29/4/25 at 02:10 PM Reply With Quote
un-hitch it, turn it. then re-hitch
strangely, bigger trailers are easier to reverse.
but the biggest win is: try not to get into a situation where you have to reverse.
coyoteboy
posted on 29/4/25 at 03:28 PM Reply With Quote
I've been planning a camera based replacement to the rear view mirror since autoglass damaged my mirror while changing the screen. But that's a fair way away. I'd not found any super cheap whip antenna, this might be the answer in the short term!
Long trailers are definitely easier, I normally tow a 30ft boat trailer and that's a piece of cake to reverse up devon lanes compared to this! Getting out is not possible due to my inflated pride not allowing escape from the doors.
jacko
posted on 29/4/25 at 05:11 PM Reply With Quote
Visit a charity shop and get one or two fishing rods
As someone said un hitch put the trailer where you want it , it helps to have a jockey wheel
G
555
Mr Whippy
posted on 29/4/25 at 07:35 PM Reply With Quote
Put the trailer in the back of the Hilux or just use the Hilux as a pickup.
adampage
posted on 30/4/25 at 07:56 AM Reply With Quote
What about bike flags?
Quick search on Amazon.....
https://www.amazon.co.uk/Trailer-Waterproof-Mobility-Mounting-Supplies/dp/B0DG2M51T5/ref=sr_1_2_sspa?th=1
https://www.amazon.co.uk/PEUTIER-Adjustable-Reflective-Fiberglass-Accessories/dp/B0CYPD9NYT/ref=sr_1_9?
https://www.amazon.co.uk/Awayhall-Bicycle-Mountain-Flagpole-Fiberglass/dp/B08XK84MYS/ref=sr_1_16_sspa?
Cheaper, one of them comes as a pair, and up to 6ft tall, should work
Good luck!
posted on 30/4/25 at 09:14 AM Reply With Quote
...ooooh cracking idea, using a pickup as a pickup
posted on 30/4/25 at 10:41 AM Reply With Quote
Ages ago I put a ding in my car's rear bumper with a small trailer, but that was when I had to reverse for a huge tractor coming the other way, and had forgotten that I had the trailer attached!
Most times I did unhook the trailer if I needed to reverse, as it was way easier. I once towed a car trailer (taking my Locost to its SVA) and that was so much more manageable - though a bit unnerving seeing the from end of a car about 2ft from my rear windscreen at 60mph!
coyoteboy
posted on 1/5/25 at 09:23 AM Reply With Quote
I was a little disingenuous, it's a Hilux Surf, I just shorten it for ease. I'm able to make that leap on my own
[Edited on 1/5/2025 by coyoteboy]
coyoteboy
posted on 1/5/25 at 09:26 AM Reply With Quote
Yeah I last used it to dump a load of wood at the tip, it was too heavy to manhandle and as you can imagine it's always a rush in a tight loop to park in a council tip. No time to re-aim and go again or you end up with 10 other cars honking to get out past you. By the time I can see the back corner of the trailer, I'm about 3 inches movement from jackknife.
posted on 1/5/25 at 02:39 PM Reply With Quote
In my case, it was a camping trailer behind a Toyota Yaris - not a big car! - and when driving in straight line I simply couldn't see it. It had props at the back for the times when I used to unload a 150lb model steam loco, so I stuffed poles into the prop tubes to give me a clue when reversing. Helped a little, but I still got it wrong now and again.
One of the members of my old model engineering club was a professional HGV driver (highest category). He used to reverse our club portable track trailer around an s-bend straight into a garage, without a moment's hesitation... bastard!
[Edited on 1/5/25 by David Jenkins]
coyoteboy
posted on 2/5/25 at 04:02 PM Reply With Quote
Good luck!
That's the ticket! Good find!
jollygreengiant
posted on 3/5/25 at 08:57 AM Reply With Quote
Have you thought about welding (or bolting) a "visible" metal hoop to the top front or Back of the trailer.
I once borrowed a small box trailer to tow with my SD1, you couldn't see the trailer (except at 90mph when it was bouncing up and down), but you could see the hoop. a great help when reversing.
MikeR
posted on 4/5/25 at 03:26 PM Reply With Quote
Why not get two bits of inch by inch wood and attach to the trailer?
My dads solution was more practical. he got 3 bits of angle iron and bolted two to the sides and one across the top - this could then be used to tie taller things to the trailer so they didn't hit the car.
