Author: Subject: No full beam on Stuart Taylor
John G
posted on 30/5/25 at 05:37 PM Reply With Quote
I have a factory built Stuart Taylor and I cant get any full beam . I have the ford indicator light surround at the steering wheel. Strange thing is that the blue light is coming on at the dash when I go to full beam. Any pointers?
Regards, Jon
jacko
posted on 30/5/25 at 07:58 PM Reply With Quote
I’m not a electrician but I would be looking at lose wires or wires that have come off
Also check relays are ok and working
Jacko
Ps are the bulbs ok
555
Mr Whippy
posted on 30/5/25 at 08:08 PM Reply With Quote
Usually the dash light is tied into the feed from the relay for the lights so is a bit strange, as both dip and main share the same earth that's also odd. Have you tested the bulbs or if there is power going to them? I had only one indicator working on old car and assumed the relay had failed, turned out I had 3 blown bulbs! check the easy things first and don't assume.
jelly head
posted on 31/5/25 at 08:02 AM Reply With Quote
A short somewhere between the blue light and the bulbs?
