robinsoncrusoe55
posted on 6/6/25 at 09:53 AM |
Cross flow Engine
1 for the crossflow engine experts ........
Can a 1600 cc head be fitted to a 1300cc engine. ?
Many thanks
posted on 6/6/25 at 10:47 AM |
Yes if you have the type of head that is flat , not sure if you have the chamber type heads
gremlin1234
posted on 6/6/25 at 11:55 AM |
if I remember correctly, changing heads between engine sizes would allow you to mix and match compression ratios, but that may have been triumph
engines rather than ford.
gremlin1234
posted on 6/6/25 at 01:51 PM |
or maybe bmc engines A series
robinsoncrusoe55
posted on 6/6/25 at 02:47 PM |
Hi rusty nuts , yes both are flat heads with combustion chamber in the head of the piston , so sounds like it's doable.
Gremlins 1234 - I think in my case , I would have to change the pistons to alter the compression ratio .
.....was just considering a head swap , because the inlet valves are slightly bigger , so head would flow better .
trialsman
posted on 8/6/25 at 03:06 PM |
I did on my engine swap. Worked great. Just make sure you swap flat squish area for flat squish area. Russ
robinsoncrusoe55
posted on 8/6/25 at 10:41 PM |
Hi trialsman .... (Russ)
Yes , my fitted engine is the 1300cc from a mk2 Ford escort with the flat head and bowl in pistons .
Replacement head is similar design from a 1600 cc with the larger inlet valves , not sure about the exhaust valve size.
Believe that some of the earlier heads had a semi chambered design , but have not seen this type .
trialsman
posted on 9/6/25 at 12:11 AM |
MAKE SURE THE VALVE SEATS ARE HARDENED FOR UNLEADED GAS. RUSS
joneh
posted on 9/6/25 at 06:33 AM |
The 1300 and 1600 heads are the same. It was only the GT that had larger valves.
robinsoncrusoe55
posted on 9/6/25 at 07:34 AM |
Current head hasn't got hardened seats, but using super unleaded and an additive , probably not ideal ,
but compression is still reasonable.
Hi joneh , the 1600 cc head must be from a gt , as the inlet valve head diameter is definitely larger ....
but didn't know that the non gt head valve sizes are the same. Thanks .
