Author: Subject: Lever arm dampers, check the oil
Mr Whippy
posted on 16/12/25 at 04:45 PM Reply With Quote
So now is proper winter I have taken old car off the road but just before that I decided to jack the thing up and change the oil in the old lever arm dampers (dampers not shocks). The cars handling has been a bit mental especially over some bumpy roundabouts with the backend almost leaving the ground which I put down to it being a crappy handling old car, however I discovered this was not the case. Note that since I got the car I have only topped up the oil from the filler bolt, but not removed the top cover, as that was what was in the service manual.
As I was removing the damper I noticed that the arm was incredibly stiff to move, like I could barely move it at all. I then opened it up only to smell that very distinctive pong of diff oil FFS! That's like treacle compared to 3 in 1 oil. These dampers are known to leak a bit of oil and so some idiot thought using thick oil was the fix. I flushed out all dampers with WD40 and refilled with 10w fork oil.
OMG the car is totally transformed! it just floats along so nice it's amazing what a joy and all the bad handling is gone, it does lean a bit more in corners but such an improvement. I'm kicking myself for not doing this 3 years ago...
So if you have an old car with this type of damper as they are used in many classics, it might be worth you doing the same, especially as the fork oil cost just £5.30 from Halfords. Removing, cleaning and refilling all four took only about an hour.
Bye.
coyoteboy
posted on 17/12/25 at 11:15 AM Reply With Quote
Shocks are dampers - it's a synonym?
jacko
posted on 17/12/25 at 04:32 PM Reply With Quote
I maybe wrong but a damper is like what you get on a motor bike steering that dampened the movement
Would you use a shocker on a motor bike steering ?
555
cliftyhanger
posted on 17/12/25 at 05:42 PM Reply With Quote
Technically springs are the shock absorber, and dampers errrrr damp the suspension movement.
However, 99.99% call dampers shock absorbers.
SteveWalker
posted on 17/12/25 at 09:26 PM Reply With Quote
To be fair, while the spring does absorb the shock, it then releases that energy again. It is the damper (or shock absorber) that actually takes the energy in and turns it to heat, to stop it being released as mechanical energy again.
Mr Whippy
posted on 17/12/25 at 10:58 PM Reply With Quote
Exactly.
coyoteboy
posted on 18/12/25 at 12:07 AM Reply With Quote
Yes so just to be clear, the engineer in me is a pedant, shocks and dampers are the same thing, a combined spring and shock are just that (a coil over).
Dampers control spring movement by converting kinetic energy into heat, they absorb and dissipate. Springs *store* and then return energy with no (appreciable) damping effect, and cannot be considered a shock absorber. I may live in an echo chamber but I don't know anyone who called a spring the shock (and I'd rant at them if they did &#129315
[Edited on 18/12/2025 by coyoteboy]
Mr Whippy
posted on 18/12/25 at 12:33 PM Reply With Quote
It's probably American term, they always get things wrong
gremlin1234
posted on 18/12/25 at 01:19 PM Reply With Quote
so have your tyres been doing the majority of the suspension for 3 years (and maybe a lot more time before you owned it?)
Benzine
posted on 18/12/25 at 08:24 PM Reply With Quote
Current project uses lever dampers and the oil smells like dead fish. I've also read about people swearing by fork oil so I was going to go down that route. Nice to see that confirmed here by a trustworthy source!
Mr Whippy
posted on 18/12/25 at 08:40 PM Reply With Quote
More my back, just as well the seats are soft!
Mr Whippy
posted on 18/12/25 at 08:47 PM Reply With Quote
Yeah if it smells bad, that's probably the wrong oil. They are really simple to clean out, just remove the top cover and the lower bolt, you can remove the valve thing. I just flushed it with WD40 till it came out clear, then refilled with the fork oil. It's so simple I am going make it a yearly task and that way I can get the most life out the things as they are about £140 each as replacements. I have not looked but I think the shaft can be bushed out if that is worn since the case is just aluminium, it would just need a pillar drill and reamer. Standard size bushes and oil seals you can order online. A task for another year though.
cliftyhanger
posted on 19/12/25 at 09:10 AM Reply With Quote
I got nosey with teh fork oil thing.Seems there are MANY but this post proved useful https://www.vfrdiscussion.com/index.php?/forums/topic/84687-fork-oil-sae-comparo/
it seems most are around a 5W oil but all have different viscosity. You could probably use 5-30 or even 10-40 engine oil and get the same sort of results. Handy if that is what you have on the shelf.
Mr Whippy
posted on 20/12/25 at 11:01 AM Reply With Quote
I simply got the only folk oil Halfords sold. I would not use any engine oils as they are a lot thicker than the 5w fork oil, think 3 in 1 oil and your more likely to just make things worse, it needs to be thin oil.
[Edited on 20/12/25 by Mr Whippy]
jacko
posted on 24/12/25 at 05:11 PM Reply With Quote
How about. Oil you use in a trolley jack ?
G
555
Mr Whippy
posted on 26/12/25 at 10:41 PM Reply With Quote
G
I'm not sure but fork oil is for going through damper valves so is likely to be just the right grade.
