Author: Subject: Towing limits
Slimy38
posted on 24/1/26 at 08:51 AM Reply With Quote
Towing limits
Good morning, I have a small towing question. I'll be trailering my car to the IVA and I wanted to check I'm within limits. My Skoda Superb has a tow capacity of 1800Kg, the trailer I'm hiring is 670Kg and the car is 770Kg. Basic maths suggest I'm within limits, but the trailers gross weight is 2600Kg. I have a vague recollection that the towing capacity needs to exceed the gross weight even if you're not using it.
I'm fairly confident the Superb is capable (and it wouldn't have got so many 'caravan tow car of the year' awards if it wasn't), but I am wary of the gross weight. Problem is outside of some random posts on here and elsewhere, I can't find anything official. Everywhere I look it talks about the Maximum Authorised Mass, which is the number related to the towing vehicle not what is on the trailer.
I've already checked my licence, thankfully I'm old enough to have the trailering categories and they're still there.
posted on 24/1/26 at 11:51 AM Reply With Quote
I believe it's done off the rated limits rather than actually weights, on the basis that the police can't actually weigh it on the road side. However, it's ludicrously unlikely you'll get stopped. I have towed enormous trailers literally up and down the country, even homemade ones, and never been stopped.
Pretty sure everyone has the +E now though don't they? Didn't they just add it through covid?
obfripper
posted on 24/1/26 at 12:38 PM Reply With Quote
Look at your vin plate, there will be 4 weights listed, take the first weight(MAM) away from the second (GTW/GCW) and that will give you the normal trailer capacity, and may be slightly different to the weight stated on your v5 due to how the manufacturer calculates that figure.
AFAIK the figure stated on the v5 can override this, but I'm not 100% sure on this, I've noticed several cars that have a braked trailer figure of say 1500kg, but only 600kg unbraked which does not seem to correlate to the law.
There is also some leeway in that if the car isn't fully laden, that difference to the MAM can be used for the trailer to remain legal as long as the GTW and trailer plated weight are not exceeded.
If you were stopped for overloading, they would use the actual weights of the vehicle and trailer to determine it's legality as towed, not the trailers plated weight (unless exceeded), and they would have to lead you to the nearest weighbridge to determine this. There is also a 5% allowance in your favour before an offence is applied, ie a 3500kg GTW would have to exceed 3675kg to be legally overweight.
Things like the "85% rule" are caravan club recommendation, not the law, and are only intended to help inexperienced towing drivers, hence it is fine to pull a 3500kg trailer with a c.1700kg unladen landrover defender.
Dave
Slimy38
posted on 24/1/26 at 12:57 PM Reply With Quote
Aye, I took my numbers off the VIN plate because I can't find my V5 at the moment. Car weight is 2139 and total weight is 3939 for the 1800kg towing capacity.
Thanks for the responses both, I appreciate it's not strictly to the letter of the law but given I'm not taking the mick and staying withing the actual limits of my car and myself I think I'm good.
gremlin1234
posted on 24/1/26 at 03:29 PM Reply With Quote
some of the towing limits on cars are what the manufacturer 'guarantees' for a restart on a significant hill (about 1 in 8 at sea level with a fully laden car).
gremlin1234
posted on 24/1/26 at 03:44 PM Reply With Quote
thinking further, the car spec works with gross train weight (ie total real weight), but licence works on mam, maximum authored mass of the components added together.
it should be fine.
no-one would notice, except if you happened to arrive at a dvsa/vosa test station... So perhaps ask them first
gremlin1234
posted on 24/1/26 at 03:58 PM Reply With Quote
Originally posted by obfripper
I've noticed several cars that have a braked trailer figure of say 1500kg, but only 600kg un-braked which does not seem to correlate to the law.
The max un-braked trailer is 50% of the cars curbside weight (upto max of 750kg)
