Author: Subject: Zetec silver top alloy sump v black top steel sump
axle
posted on 29/7/26 at 10:24 AM Reply With Quote
Hi all
I do not have alloy tig welder to shorten my alloy sump ( 1.8 Silver top ). Am l correct that the black top have steel sump? Does anyone know If the bottom of the block fixing are the same than l can modify the steel as l can weld steel.
Regards Axle
jacko
posted on 29/7/26 at 01:12 PM Reply With Quote
As far as I can remember yes a steel sump fits
If you are cutting the bottom off it needs to be cut slanted to the top part that bolts to the block .
This way the bottom off it the sump is straight with the chassis and the rocker cover
From what I can remember you may need a steep pick up pipe to alter
Graham
I am sure someone will be along that know more then me
555
axle
posted on 29/7/26 at 01:24 PM Reply With Quote
Thanks Graham for your reply all l did to know was if the fixing holes on the bottom of the block were matching.
Thanks again for other information.
Regards Alex
[Edited on 29/7/26 by axle]
Regards Axle
fazerruss
posted on 1/8/26 at 09:45 PM Reply With Quote
The black top sump is in two parts. The steel sump is only a small portion of the sump. There is also a large aluminium windage assembly between the block and the steel sump.
I believe the alloy sump on the silver top is one piece so you're going to need more than the steel part.
"if assholes could fly this place would be an airport"
jacko
posted on 2/8/26 at 05:53 PM Reply With Quote
Im very sorry the steel sump I altered was to fit a 2l black top but I can’t remember if the sump came of a black top or a silver top engine maybe off a different model Ford car
G
555
fazerruss
posted on 2/8/26 at 06:11 PM Reply With Quote
Here's what the sump looks like and me altering the windage assembly to have more fixing points for the Type 9 bell housing
axle
posted on 2/8/26 at 07:50 PM Reply With Quote
Well thanks all for your replies it's the Zetec silver top sump l was trying to modify steel from black top. It looks like l have to make one from scratch has anyone done this before it will be a massive help?
Regards Axle
