Author: Subject: Zetec silver top short sump
axle
posted on 5/8/26 at 04:13 PM Reply With Quote
Has anyone got one for sale to suit locost?
Regards Axle
fazerruss
posted on 6/8/26 at 09:17 PM Reply With Quote
Referring back to your other post about not being able to weld aluminium, if you cut down your existing alloy sump and send it down to me I can weld an aluminium plate on the bottom for you.
"if assholes could fly this place would be an airport"
axle
posted on 7/8/26 at 08:58 PM Reply With Quote
Thanks so much for your offer l do appreciate tig welding can be very time consuming not very easy with fords alloy either. I do have a friend who can do it for me l was hoping to get one made already if not l shall have to ask him. Once thank for your help very kind of you.
Regards Axle
John G
posted on 17/8/26 at 06:39 PM Reply With Quote
I have a ATR shortened sump on the bottom of a Zetec Blacktop block, the head has been removed for bore inspection which is all good. Message me if interested.
Regards Jon
axle
posted on 18/8/26 at 07:56 AM Reply With Quote
Hi
Thanks for your reply, not sure if the black top will fit the silver top. However worth a try please pm some pic and your asking price.
Regards Axle
fazerruss
posted on 18/8/26 at 08:04 AM Reply With Quote
The black Top and silver top engines use the same cast iron cylinder block
The heads are also very similar but silver top uses hydraulic cam followers but the black are solid.
Also as said earlier the sumps are completely different.
axle
posted on 18/8/26 at 06:35 PM Reply With Quote
Thanks again for clearing that up, do you know if the Silver top were fitted with steel sump?
Regards Axle
fazerruss
posted on 18/8/26 at 07:02 PM Reply With Quote
As far as I know the silver tops always had alloy sumps
