Author: Subject: Need a readable wiring diagram
trialsman
posted on 5/8/26 at 05:18 PM Reply With Quote
Where can I get a readable wiring diagram for my Locost's 1979 Ford Escort Estate donor? The Haynes manual wiring diagrams sucks. Any suggestions? Russ
trialsman
posted on 6/8/26 at 02:00 AM Reply With Quote
Ok I’m at my wits end on this darn car. It died on me while on holiday and I put it in the trailer to sort it out when we got home. I think I traced it down to an ignition problem. So I tore out the old two position switch and the push to start switch and put in a standard 4 pole turn to start switch. Worked great. Took it out tonight to get gas. Turned off the ignition at the station. No problem. Got home and turned off the ignition. Engine keeps running. Reach over to the kill switch. Turn it off and the engine keeps running. It's not dieseling. Generator/oil pressure light is on. Remove the bonnet and pull the coil lead off and it still wants to run but finally stops after a few seconds. I did not touch the kill switch wiring when I replaced the ignition switch. Any ideas??? Russ
JAG
posted on 6/8/26 at 06:56 AM Reply With Quote
I'm sorry to hear you're having trouble.
To be honest I've used the Haynes diagrams before - they are pretty good. However it doesn't take much to find other diagrams. Like this one...
[Edited on 6/8/26 by JAG]
Justin
trialsman
posted on 6/8/26 at 12:42 PM Reply With Quote
Justin, where did you find that diagram? Russ
JAG
posted on 7/8/26 at 07:03 AM Reply With Quote
It was on Pinterest
Justin
Dingz
posted on 20/8/26 at 07:47 PM Reply With Quote
Has it got an electric fan fitted and was it running when the ignition was turned off?
went on and on.
trialsman
posted on 20/8/26 at 08:42 PM Reply With Quote
Yes it has an electric fan and no I don't think it was running at the time this happened. Why? Russ
gremlin1234
posted on 21/8/26 at 04:36 PM Reply With Quote
if you have an electric fan fitted, switched from the 'ignition live', and
turn the ignition switch off,
the overrun of the fan can act as a generator,
powering enough of the ignition circuit to keep the engine running.
edit: relays can cure this.
edit2: or you could power the fan from the unswitched live. but beware it could run without the engine on, and the fan may start quite a while after being parked,
this will munch any nearby human fingers without warning...
[Edited on 21/8/26 by gremlin1234]
