<<  1    2  >>
Author: Subject: placing v8 into book chassis
DOEHEAD2
posted on 8/2/05 at 11:49 AM Reply With Quote
is it possible at little expense to place a rover v8 into a book chassis using a type 9 gearbox?
blueshift
posted on 8/2/05 at 12:18 PM Reply With Quote
Darren from GTS tuning said once that a rover v8 will fit a book chassis. Plumbing it in and routing the steering column etc though, would be Rather Interesting I expect.
As for mating to a type 9, I have no idea.
I and the other two builders I know who are using the rover v8 are starting with a +4" wide chassis.
need4speed
posted on 8/2/05 at 01:16 PM Reply With Quote
I doubt a type 9 box would last very long you would need either t5 or a rover lt77/r380 box on the back of a v8
Simon
posted on 8/2/05 at 11:27 PM Reply With Quote
As blueshift says, routing steering column may be interesting. My chassis +4" and engine compartment is quite tight as it is.
See my pics in archive Particularly : http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2003_1217Image0024.JPG
Wouldn't bother with Type 9 - stick with LT77 or if you're rich, get an R380.
I have plenty of footwell space with the +4 and that extra 2" a side widens the seat availability!
Simon
[Edited on 8/2/05 by Simon]
DOEHEAD2
posted on 9/2/05 at 10:57 AM Reply With Quote
hi thanks for all replies!
the fact is that i want to replace the pinto that is in the car at the moment for something with a bit more grunt at little expense so i thought about the v8 for the more grunt and the sound factor, could anyone suggest anything else that would fit without to many mods to existing chasis / car replies much appreciated.
blueshift
posted on 9/2/05 at 01:00 PM Reply With Quote
4AGE? not that I know much about them. at all. but they're not too huge afaik
DOEHEAD2
posted on 9/2/05 at 02:53 PM Reply With Quote
ive heard the 4age engine is very expensive and only a little bit better than the zetec or 16v vauxhall is this true?
NS Dev
posted on 9/2/05 at 05:51 PM Reply With Quote
4age is quite a bit smaller and easier to find room for with a decent sized sump than the vauxhall and the zetec. however, if you got a pinto in there with a sump on it then all three will fit ok..................in which case it's not the cost of the base engine which is the worry, but the cost of getting it running in the car.................in which case the 4age and vauxhall will be cheaper because most will have a distributor on them, giving some basis for an ignition system, so you can then run carbs for fuelling. the zetec never had a distributor so you have to solve the ignition before you can do anything else.
The 4age is a very neat, light and compact engine, the vauxhall is quite heavy and rather bulky, the zetec slightly less so..................the choice is yours!!
NS Dev
posted on 9/2/05 at 05:52 PM Reply With Quote
PS Cheapest option for decent power and fun is without doubt a bike engine!!!
craig1410
posted on 9/2/05 at 09:49 PM Reply With Quote
I'd have to disagree NSDev, if you can fit the Rover V8 in then you could buy three V8 engines for the price of a bike engine of similar power output. Mine only cost me £175 with all ancillaries and this has turned out to be a genuine engine which is in excellent nick and ready to run without any work to be done. Okay for the V8 you also need a gearbox but I got a good 'un for just £130 making it £305 all in.
As for fitting it in a standard book chassis, I can see how it might be done but you'd have to use tubular exhaust headers to enable you to make some room for your steering link. You would also need to get the engine quite far back which would eat up some footroom due to the wider trannie tunnel. This all said I'd say it's very do-able.
Here is a link to some photo's of my chassis when I was at the engine fitting stage.
[Edited on 9/2/2005 by craig1410]
stevebubs
posted on 9/2/05 at 10:05 PM Reply With Quote
Ford Duratec. Probably not the cheapest solution, though.
Alternatively, N/A Cossie engine
NS Dev
posted on 10/2/05 at 12:24 AM Reply With Quote
I'd like to disagree with myself since I'm not using a bike engine!!!
However, my 200hp vauxhall engine will only put me on a par in terms of power to weight with a fairly tame bike engined car, and with the best will in the world, a sub £200 Rover V8 aint going to put out more than 180hp!
I'd like to say it would but I have seen too many on the rolling road to be able to say so!
DOEHEAD2
posted on 10/2/05 at 08:21 AM Reply With Quote
do i need any special gearbox adaptor flanges for vauxhall to ford box or 4age to ford box?
craig1410
posted on 10/2/05 at 09:49 AM Reply With Quote
I agree, my engine as standard will put out 155BHP (SD1 on SU carbs) but with a pair of K&N filters, my 3" bore straight through twin side-pipe exhausts and a new camshaft it will easily break 200BHP and still be a reliable big lazy V8 rather than a tempramental highly tuned buzzy engine. Obviously I'll need to get the carbs jetted to suit the changes but that's easy enough with SU's. The camshaft kit will set me back a few quid (est. £150) but it's still well under the price of a bike engine.
At the end of the day the BEC vs V8 argument has been done before and it's swings and roundabouts and ultimately ends up a personal preference issue but you can have major amounts of fun with even a 155BHP V8 and probably too much fun with a 200BHP V8!!!!
Craig.
Simon
posted on 11/2/05 at 12:04 AM Reply With Quote
And Craig, don't forget the torque.
My new brum brum has about 400nm and pulls away in second - in a car weighing 1700kg.
Imagine 200ftlb (nm?) in1/2 ton. Should be able to pull away comfortably in third or fourth
Simon
craig1410
posted on 11/2/05 at 12:34 AM Reply With Quote
Simon,
You are quite right, the V8 should be able to produce the best part of 280NM which in a 600Kg car should feel like the hand of God at your back...
I can hardly wait.....
Craig.
NS Dev
posted on 11/2/05 at 11:31 AM Reply With Quote
And it'll sound better than a bike engine too! (just to prove I'm not biased!)
DOEHEAD2
posted on 17/2/05 at 11:25 AM Reply With Quote
ive recently been offered a cheap 2.5 v6 duratech from scrappers, i can only assume from all the talk on the forum that the duratech will fit into a book chassis can anyone tell me if this is correct before i waste my money?
kreb
posted on 17/2/05 at 03:53 PM Reply With Quote
I dunno if you guys have enything with the GM 60 degree pushrod V-6 on that side of the pond, but it's a good alternative to the Rover. It comes in at about 350 lbs. and with a few bolt-ons will give you 200 HP/200 ft. lb. A valve spring change will make it rev to 7K, and it's quite compact.
https://www.supercars.net/blog/wp-content/uploads/2016/04/1966_FiatAbarth_1000SP1.jpg
Simon
posted on 17/2/05 at 07:56 PM Reply With Quote
Yeah, but it's got a couple of things missing.
One cylinder on the left and one on the right
Simon
craig1410
posted on 17/2/05 at 10:14 PM Reply With Quote
I wouldn't mind the V6 engine out of a Metro 6R4 though!!! It is based on the Rover V8 with a pair of cylinders chopped off and has some serious power potential (410 BHP+ IIRC)
Craig.
Ferg
posted on 18/3/05 at 04:15 PM Reply With Quote
I wouldn't mind the V6 engine out of a Metro 6R4 though!!! It is based on the Rover V8 with a pair of cylinders chopped off.
Er....no it isn't.
ned
posted on 18/3/05 at 04:25 PM Reply With Quote
there was an article on this recently in pcc, the early 6r4 engine were bsaed on the rover v8 block but by the time it was fully developed it had lost all its connections with the rover unit..
Ned.
beware, I've got yellow skin
posted on 18/3/05 at 04:29 PM Reply With Quote
I remember a rallycross programme on BBC (when they used to show it ) where one 6R4 had been fitted with a turbo (maybe 2).
He had to be very careful not to floor it on the rough corners 'cos he used to tear the wheels out of the tyres... and the tyres were bolted to the rims...
Ferg
posted on 18/3/05 at 04:31 PM Reply With Quote
It's a myth that keeps cropping up. The 4WD system in the car was developed using a cut down RV8, but the V64V engine is in NO way related, in fact it owes more to the DFV than any other previous engine.
<<  1    2  >>
