Author: Subject: Topsy Turvey Rad
tr
posted on 15/2/05 at 06:26 PM Reply With Quote
Topsy Turvey Rad
Quick illustrated question.
Whichis the top? A or B?
I think A is the top, as it's got the 90degree angle on it and it'd be no good to drain from. However, if it is this way round will I get and air bubble in the top of the rad? I've got more photos if needs be.
tr
theconrodkid
posted on 15/2/05 at 06:34 PM Reply With Quote
whats it from?looks up-side down and the "a" outlet should go sideways(to the outside of rad)
who cares who wins
pass the pork pies
JohnN
posted on 15/2/05 at 06:35 PM Reply With Quote
My vote goes for "B" to be the top, for the reason you identified - air locking.
JohnN
posted on 15/2/05 at 08:11 PM Reply With Quote
When you get to put the rad on the chassis I think you'll be very glad of the 90-degree bend at end A at the bottom. Otherwise you may well find that the bottom outlet will be pointing straight at the lower chassis rail!
tr
posted on 18/2/05 at 07:06 PM Reply With Quote
B is the top, I've sat infront of it for half an hour and twiddle it about. I think your right, if A stays at the top it'll never fill up properly. Also, the fan switch will need to be at the top with the hot water.
Decided. I'll refit it the right way up tomorrow.
