Author: Subject: fuel hose for water?
scutter
posted on 17/2/05 at 09:04 PM Reply With Quote
As it say's above can 8mm fuel hose be used as water hose, as i need to plumb in my Dolomite header tank in?
Thinking of doing it as below.
ATB Dan.
[img][/img]
indykid
posted on 17/2/05 at 09:43 PM Reply With Quote
i have and have had no problems.
afaik, water will be held in any rubber hose, fuel needs to be special hose as it eats some rubbers, brake fluid can get through the gaps in normal hose so again needs its special hose
that's my understanding anyway
routing looks reasonable as long as the tank will actually feed the system, ie water level above thermostat housing
hth
tom
posted on 18/2/05 at 12:57 AM Reply With Quote
Most of the time - water can run through petrol pipes but not vica versa
scutter
posted on 18/2/05 at 08:05 AM Reply With Quote
Excellent, time to go shopping.
Many thanks Dan.
Danozeman
posted on 18/2/05 at 09:11 PM Reply With Quote
Ive been running this on my calibra for ages as i couldnt get 8mm coolant hose and needed it quick. NO probs
Dan
fester
posted on 24/2/05 at 08:54 PM Reply With Quote
Water/fuel hose
If in doubt,contact your local hydraulics company(there is a Pirtek almost everywhere now) and ask them for 3/8" P.O.A. This stands for petroleums,oils and air. This stuff is very flexible, cheap and has a good burst pressure(which is the important bit!). It also looks good!
Good luck!
fester
posted on 24/2/05 at 08:59 PM Reply With Quote
Water/fuel hose
CORRECTION! Don't ask for 3/8",ask for 1/4" which is equivalent to 6mm.......DOH!
scutter
posted on 24/2/05 at 09:51 PM Reply With Quote
Cheers fester, got fuel hose from premier wiring 5/16 is 8mm which is what i need and rated upto 150psi
ATB Dan.
