Author: Subject: rack extensions
RICK1
posted on 21/2/05 at 09:26 PM Reply With Quote
rack extensions
any 1 tell me length of rack extesions on velocity xt. just fitted mk2 escort steering rack and would like 2 make these myself cause bits take 2 long coming from luego?
spud u like
posted on 27/2/05 at 08:22 PM Reply With Quote
trackrod end
thay are 112 mm long
there is a solid round bar that has been drilled out and tapped this is 77 mm long
then there is the threaded end this is 35 mm long this end goes onto the trackrod end you will need two nuts so you can lock it off
