clbarclay
posted on 1/3/05 at 02:34 PM |
braket size
About to start making the brakets for mounting suspension to.
What is the distance between the pivot centre and the base of the braket, the book (2nd edition) is not to clear. Is it nearer 22mm or 25mm.
If your not to sure about which dimension I mean then see diagram bellow, dimension marked X.
![](/galpreviews/a186814-Sus. braket.JPG) ![Rescued attachment Sus. braket.JPG](/gallery/a186814-Sus. braket.JPG) Rescued attachment Sus. braket.JPG
flak monkey
posted on 1/3/05 at 02:46 PM |
In the book the holes are 18mm from the top edge of the bracket as you have drawn it above....which puts them at 20mm from the base of the
bracket...(page 62 in the 2nd edition book)
Sera
http://www.motosera.com
James
posted on 1/3/05 at 03:07 PM |
With some of my (bought) brackets they're 22mm (IIRC) and I've had some trouble fitting the ProTech shock absorber in.
So make them with enough distance to get your shock in place easily.
James
- Muhammad Ali
clbarclay
posted on 1/3/05 at 03:23 PM |
Only making the wishbone/tailing arm/panhard at the moment so will deal with damper mounts latter.
Flak monkey, I don't trust that diagram it measures the base at both 48mm (right hand pic in diagram) and also at 39mm (left hand pic in
diagram)!!!
Even if the 39 is internal it still doesn't add up.
looking at the diagram on page 63 it looks like 22mm with a 3mm plate under the braket for the lower rear mount of wishbones.
timf
posted on 1/3/05 at 03:29 PM |
gts brakets ar 25.4
see http://www.gtscougar.freeserve.co.uk/ubracket2.pdf
flak monkey
posted on 1/3/05 at 03:45 PM |
diagram)!!!
I see what you mean! Another error to add to the growing list!!
As Tim says the GTS ones are 1" from base to hole...
[Edited on 1/3/05 by flak monkey]
Sera
clbarclay
posted on 1/3/05 at 04:10 PM |
Well seing as how i'm using GTS bushes i might as well use brakets the same size as they do. 25mm also fits nicely down the centre of 50x50 box.
Avoneer
posted on 1/3/05 at 05:40 PM |
I was gonna say that it depends on the OD of your bone eyes, but you got to this conclusion anyway.
Pat...
Bart69
posted on 1/3/05 at 07:25 PM |
Surely someone will correct me but i think the missing mm's are in the bend itself.
clbarclay
posted on 1/3/05 at 07:45 PM |
Its not a case of losing metal more a case finding either 3mm or at worst 9mm depending whether the dimmensions are marked oninside or outside
respeciverly.
Bart69
posted on 1/3/05 at 07:54 PM |
the bend is started 39mm apart once the radius is taken in to account the finished dimension is 42mm
I stand to be corrected
graham
clbarclay
posted on 1/3/05 at 08:09 PM |
The book doesn't say anything about the radius of the corners. So I take it to mean that there is no measurable internal radious on the
brakets.
Also I wonder whether you risk weakening the brakets if you have to bigger radious there. you also reduce the ammount of clearence room at the near
the sides of the braket for the bush.
Bart69
posted on 1/3/05 at 08:23 PM |
quoting page 62 fig 4.31 internal rad =0.187
im just thinking if you bend at exactly 42mm your bracket will end up much bigger. You cant get a sharp 90 deg bend their always must be a radius and
if i remember from my dist past there is a formula incorparating thickness and radius to work it out. Just dont ask me what it is
clbarclay
posted on 1/3/05 at 09:14 PM |
Ah. well I missed that one.
Still if they put more dimensions on the pic of bent braket fig 4.31 it would probably save a lot of confusion
Just done the maths and with the radious taken into account the difference between 2 main pics in fig 4.31 is 0.024", thats not to bad.
[Edited on 1/3/05 by clbarclay]
Bart69
posted on 1/3/05 at 09:27 PM |
that whats great about this place i help you here; you helped me earlier in the chassis section
keep up the good work
graham
