Dillinger1977
posted on 9/4/05 at 08:57 AM |
R1 clocks from different bike
Hi chaps
if you're using r1 clocks, do they have to be from the same bike (ie the clocks match the engine)
or do they even have to be the same model?
im guessing if they arent then the mileage wont match up, but will there be any other drawbacks? would the sva/dvla like it?
cheers
Rog
-Rog
shed
posted on 9/4/05 at 11:48 AM |
my R1 clocks come off a different bike. donot know about sva/dvla cannot see how they can tell or care as long as they work.
ChrisGamlin
posted on 9/4/05 at 01:55 PM |
Ive not read anything to suggest they are linked to the ECU, I hope not as Ive bought a set with a friend to use for diagnostics!
You might even find that the mileage still does tally with the engine as on some bikes with electronic odometer, the mileage is stored in the ECU
rather than the dash, so whatever dash you put on it will show the same mileage.
athoirs
posted on 9/4/05 at 02:22 PM |
yes there is a difference in what year engine the clocks come from.. early R1's had a second sersor on the rad for the fan later ones had a
single unit and the fan was controlled from the clocks. best get a set of clocks from the same year and you should have no problems.. I made a set of
R1 clocks work with a fazer engine...all the cable connections where different![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
