Author: Subject: Rear of the chassis pictures
Mr Perfect
posted on 10/4/05 at 04:57 PM Reply With Quote
Hi all,
I've put some more pictures of the chassis in my archive, this time it's the rear or the chassis.
Hope these are helpful to all new builders working from the book.
Just need to put the steel plate over the back part, then it's on with the suspension brackets.
Can the wishbone brackets be bought or do they have to be made?
Regards
Nik
Kitlooney1000
posted on 10/4/05 at 05:03 PM Reply With Quote
Hey mr perfect, Whats the steel plate for?
Looking good.
Lew
Doesnt matter what Sh*t life throws at you, there is always some other poor bugger worse off!!!!!
Mr Perfect
posted on 10/4/05 at 05:09 PM Reply With Quote
To strengthen up the rear frame as per book drawing? Rescued attachment rear1.jpg
Lightning
posted on 10/4/05 at 05:47 PM Reply With Quote
Those corner plates are where my roll bar back stays fit.
Mr Perfect
posted on 11/4/05 at 06:36 PM Reply With Quote
Thanks Steve,
Thought that might be the idea, can you tell me what the two in the middle of the top rail are for?
Also the small bit of flat plate in the centre behind the diff?
Regards
Nik
andrew.carwithen
posted on 11/4/05 at 07:08 PM Reply With Quote
The top two are for the base plates of the two small roll hoops (should you wish to fit them) instead of the large single rollbar.
I believe the welded plate behind the diff is there for extra strengthening should you wish to fit a rear bracket to the diff.
HTH,
Andy.
Viper
posted on 11/4/05 at 08:33 PM Reply With Quote
MR Perfect, i hope you are not implying that the pic you have posted is anything to do with you???
and the back of that particular car is quite a bit different from the avon book.
carlgeldard
posted on 12/4/05 at 07:45 AM Reply With Quote
I welded a piece of 5mm flat bar all the way across that box section were the roll bar fits.
Carl
Mr Perfect
posted on 12/4/05 at 07:17 PM Reply With Quote
Viper,
The picture posted was to show what i was describing to Kitlooney1000!
It is the same as one of the diagrams in the new edition of the Avon book that i am working from.
(Chassis section F-F Drg 6.6g)
Can anyone answer the question of wishbone suspension brackets (Bought or made)?
Regards
Nik
Mr Perfect
posted on 12/4/05 at 08:02 PM Reply With Quote
Viper
The pictures in the book don't show the steel plate and the extra bracing on the F-F section of the chassis that i am talking about, also they have box section on the roll bar mounting.
But these are shown in the diagrams.
I can see you have changed the wishbone and shock mounts is this because of a fault with the original or just your way of improving the design?
Regards
Nik
Avoneer
posted on 12/4/05 at 08:43 PM Reply With Quote
The rear end is all designed wrong in the book as the camber is all wrong when the wheels go up and down.
Think Viper has done it the right way!
Pat...
Mr Perfect
posted on 12/4/05 at 08:49 PM Reply With Quote
Thanks Pat
I will look in to this before i mount the brackets.
Nik
Northy
posted on 12/4/05 at 09:19 PM Reply With Quote
Let us all know if you solve it for f**ks sake
Graham
Avoneer
posted on 12/4/05 at 09:48 PM Reply With Quote
Graham, didn't you work out how they moved wrong?
Pat...
Northy
posted on 12/4/05 at 09:50 PM Reply With Quote
I know that you get +ve camber as the wheel rises (which is v.bad), but never worked out where the brackets needed to be to fix it.
Might have a play at modeling the suspension this year if I get time.
Graham
punker
posted on 13/4/05 at 08:32 AM Reply With Quote
mr perfect where did you get your rear uprights from and your wishbones??
carlgeldard
posted on 13/4/05 at 09:17 AM Reply With Quote
Don't get us started on the uprights again. I'am keeping my gob shut
Carl
DaveFJ
posted on 13/4/05 at 10:13 AM Reply With Quote
They are actuall on Vipers car - I beleive he made them himself..
Dave
andrew.carwithen
posted on 13/4/05 at 03:15 PM Reply With Quote
Carl
...And me!
Andy.
