A fulton
posted on 12/4/05 at 12:55 PM |
Drive shaft
Hi
Can some one Help
Can some one tell me the overall length of the push in tip Drive shaft for a sierra O/S/R with Drum brake , and if thar is more than one length shaft
that fits the sierra car.![](/images//smilies/sad.gif)
phelpsa
posted on 12/4/05 at 02:42 PM |
The off side is shorter than the nearside.
Adam
A fulton
posted on 12/4/05 at 06:19 PM |
shaft
Sorry the o/s is the long won of the too
AS this is the one that Im having the trouble with.![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif)
ayoungman
posted on 14/4/05 at 12:28 PM |
driveshafts
Although all sierras have the same wheel track width, there are different length driveshafts available. This is caused by the different widths of
differential that have been used, ie Estate diff is wider than normal by about 25mm ! Therefore the drive shafts are a different length to accomodate
the difference. If you mix and match, it is possible to either create a narrow rear end or alternatively... a super wide rear end. Obviously,
wishbones would need to be shortened/lengthened too.
A fulton
posted on 14/4/05 at 05:58 PM |
Drive shafts
Thank you ayougman vvvvvvary much
that has got me right out of the sh,t
![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif)
