albertz
posted on 23/4/05 at 07:14 AM |
Track rod ends and steering arms
I have read on here previously that pipe insulation is not acceptable to Mr SVA for sharp edge protection, as it is not deemed permanent when held on
with tape or cable ties.
What i was wondering is, if i used pipe insulation and then put some appropriately sized shrink wrap over it and shrunk it in position, would that be
acceptable? or even a couple of layers of shrink wrap on its own? whats the difference between that and the plastic nut covers that we use?
The shrink wrap over insulation would be best i think as it would probably be possible to slide it back of the track rod end for adjustment as and
when required.
Any comments, alternatives or past experiences welcome.
Andrew
flak monkey
posted on 23/4/05 at 07:58 AM |
A neater solution is to use cable gland covers (i think thats what they are) to cover the track rod end and adjuster nut. You just clip the end off
and slide it up the steering arm, screw on the track rod and nut, then pull the cover back over the track rod.
Sera
http://www.motosera.com
Danozeman
posted on 23/4/05 at 08:44 AM |
The only trouble with shrink wrap is if u shrink it youl have to cut it off to adjust the steering if needed. Apart from that it is a good idea.
Dan
posted on 23/4/05 at 01:11 PM |
Do you mean heat shrink? shrink wrap's for sarnies. I've never seen any big enough for the job you mention. The electric gland covers
are the best solution I've seen yet and they can be cut to length.
clbarclay
posted on 23/4/05 at 01:17 PM |
A quick search on CPC's site revealed heat shrink thats unshrunk at 50.8mm and will shrink to 25.4mm. If thats not big enough what is.
http://cpc.farnell.com/jsp/endecaSearch/searchPage2.jsp?Ntt=heat+shrink&newSearch=true&Nto=gland&Nty=1&N=411&Ntk=gensearch
its the 7 item down.
Fifer
posted on 23/4/05 at 01:46 PM |
Joke missed I think ![](/images//smilies/bigsmile.gif)
Petemate
posted on 23/4/05 at 04:30 PM |
Hi All
Tifosi do purpose-made TRE nut covers, they are supple cones which slip over and are retained with cable ties. Stretchy enough to fit all sizes of TRE
assemblies and SVA friendly.
HTH
Petemate
albertz
posted on 23/4/05 at 07:18 PM |
Thanks for the comments, i tried the "heat shrink" today and it worked quite well but tended to melt the insulation at the ends. I tried
to leave a bit of slack so that it could be slid back towards the rack to adjust the TRE.
I also noticed the Tifosi offering and phoned them, but no answer. I will probably either get there purpose made items or use cable glands as
suggested.
Nobody has commented on just using heat shrink on its own, would that be OK, as i asked previously it is no worse than the hard plastic nut covers is
it?
Thanks for the help so far.
Mr_Stevo
posted on 25/4/05 at 12:01 PM |
I could only find the cable glands as part of an outdoor junction box set from B&Q.
I ended up using bicyle handlebar grips they grip well and can be slid up and down to allow for adjustment.
DarrenW
posted on 25/4/05 at 02:17 PM |
Im surprised that pipe insulation is no good. im sure it was Snuggs that passed at Gosforth with insulation over his, cable tied on. Im sure he will
confirm but iirc he had to use the high density stuff. When fitted you can bearly feel the nut when you press thumb into it (grey colour - insulation
that is not your thumb!).
Maybe the spec has changed or tester interpretation is different elsewhere.
NS Dev
posted on 27/4/05 at 10:58 AM |
quote: Originally posted by Petemate
Hi All
HTH
Petemate
They do indeed, but they are just the cable gland covers!
omega 24 v6
posted on 27/4/05 at 11:31 AM |
What you are looking for are cable gland shrouds for micc cable available in packs of ten from all electrical hole sailors![](/images//smilies/bigsmile.gif)
they are usually orange or red coloured but i think black are also available but check first. The other type are usually only available as part of a
gland kit for swa cable and are usually in pairs. Sizes vary from around 20mm to 50mm dia and possibly larger.
Wow thats a lot of available's![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
