Author: Subject: Flashing Main beam using Sierra Column
b1lly
posted on 4/5/05 at 07:46 PM Reply With Quote
Help!.
I am assisting a friend building a Luego and we have stumbled upon a wiring issue using the Sierra Column switches/Sticks. The Main and Dip switches seem to provide a route to earth so we have adapted the Luego Relay wiring loom to allow us to send +12 to the sierra switch where that provides the earth. All works.
When trying to use the Main Beam flash wire (labelled 15) gives me +12V when flashed. So I have added another Relay and use this + 12v to create anther route to earth for the Main beam and hence the lights flash when required.
The problem is when It flashes the relay makes a buzzing noise and I guess it is because there is low voltage or low current from the switch. Does anyone have any idea how i can get around this and still use the Sierra column. My only alternative would be to use a separate switch.
Any thoughts greatly appreciated!
saigonij
posted on 4/5/05 at 07:57 PM Reply With Quote
we have managed to use the relay pakc with out adapting it, and using the sierra stalks.
i cant remember the exact method we used to wire it up, but i can give you details when i get down to the kit car.
posted on 4/5/05 at 08:07 PM Reply With Quote
We managed it too with no problems? Odd...
Thinking about this last night, you haven't inadvertently wired it into (or included) a non-loaded indicator relay have you? This would give a similar result.
[Edited on 5-5-05 by Hellfire]
b1lly
posted on 5/5/05 at 08:41 AM Reply With Quote
Good thinking but no the flasher relay isn't the problem. In fact if i take a battery 12v and connect it to my wiring it works fine. It is only if I use the 12v from the flasher switch.....wierd. I Wonder if maybe the switch is knackered.
The reason for posting is I see from so many threads that people have a nightmarewith the sierra wiring so wondered if there was an easy fix. All the lights, and flashes / indictaors work fine, just the Main flasher....
posted on 5/5/05 at 08:56 AM Reply With Quote
Have you wired the relay in incorrectly? Putting the high load through the switch maybe?
In this case it would melt the housing and not give a firm/positive contact of the faces. In which case you would need a new switching unit.
Is the buzzing consistantly timed, or is it erratic?
Gazza
posted on 5/5/05 at 10:33 AM Reply With Quote
Buzzing
Its a constant buzz from the relay - sounds like a wasp stuck in a plastic cup!
Just a bag o' rusty spanners
posted on 5/5/05 at 10:57 AM Reply With Quote
The flasher stalk just puts power from a permanent live source through the main beam relay, you shouldn't need another relay.
Northy
posted on 5/5/05 at 06:40 PM Reply With Quote
Is the 12volt well charged? I had a similar problem when installing my wiring with a flat 12volt
Graham
b1lly
posted on 5/5/05 at 10:41 PM Reply With Quote
May have found the problem (or maybe not) i was reading through an acr electronics mag and noticed you can buy Relays with a diode across the coil terminals (for sensitive circuits it said). So to mimic I connected a buld across the terminals so that lights in parallel with the relay coil and hey presto the buzzing has stopped!!!! Go figure.
Does anyone know what the why you can buy these relays? May have to pop and purchase one.
Thanks to all for your support - any thoughts on the relay would be good - I am a techy so like to understand the reason things are doing what they are do ing
Northy
posted on 6/5/05 at 07:39 AM Reply With Quote
I light bulb just went on in my head!
Yeah thats what I ended up using, probably for the same reason. I got them mail order from Premier Wiring I think.
Graham
