Author: Subject: Welding the Floor
ghvh
posted on 25/11/02 at 05:37 PM Reply With Quote
Welding the Floor
In the book it shows a 1 piece floor does this not make a water trap in the gearbox/prop tunnel. would it not be better to do it in 2 piece and leave the prop tunnel open?
theconrodkid
posted on 25/11/02 at 07:31 PM Reply With Quote
sounds like a good idea doing it in 2 peices,mine is done in 1 and you have to take the axle out to remove the prop
ps where in west london are you?
ghvh
posted on 25/11/02 at 07:38 PM Reply With Quote
Heathrow, I can see the planes from the work shop
Deckman001
posted on 25/11/02 at 07:51 PM Reply With Quote
Would't the floor being in two pieces make it weaker ? And more liable to flex and bend ?
chrisg
posted on 25/11/02 at 07:54 PM Reply With Quote
I think it should be ok, lots of people use ali floors, riveted on with no ill effects.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Deckman001
posted on 25/11/02 at 07:57 PM Reply With Quote
Good point !!
James
posted on 27/11/02 at 01:07 PM Reply With Quote
A guy at college has just taken delivery of a Luego chassis.
I noticed straight away that they use a two piece floor. The benefit I noticed straight away was that it means you can easily cut the two pieces on a guillotine!
James
elewayne
posted on 27/3/03 at 11:41 PM Reply With Quote
Ali floor pan
If you use an ali floor pan do you rivit it directly to the bottom? Or does it require some folding to rivit to the insides?
James
posted on 28/3/03 at 09:19 AM Reply With Quote
I'd have thought it's fine to do it to the bottom/underside of the rails.
The only disadvantage is that if you ground out on something then you'll rip the rivet heads off! :-(
Did mine last night- though mine are steel and I'm planning to weld them. Was all going well untill I realised I'd put the swages on the wrong side of one of them! Doh! :-(
Oh well, will only take 2 hours to re-do! :-(
James
[Edited on 28/3/03 by James]
Mark Allanson
posted on 28/3/03 at 08:42 PM Reply With Quote
Mine is in two parts, I am going to make a 3mm steel cover for the tranny tunnel, bolted in with countersunk allen bolts.
I have 13mm RHS skid tubes welded front to rear at opposite angles to stop the floor drumming with vibration from the engine (differing shape will prevent the floor reaching a harmonic frequency). It will also help if (when) I ground the car, and if I flatten one, it is easily ground off and replaced.
Mark Allanson
posted on 29/3/03 at 01:21 PM Reply With Quote
