Author: Subject: balance bar
evo3500
posted on 10/5/05 at 08:03 PM Reply With Quote
balance bar
Can anyone help,have got balance bar ,and twin brake cylinders fitted to gt1 whats the test procedure when going for sva test as mines due soon,How is the test conducted and do i need to do anything with the set up to meet the required standards for test ie lock the bar or anything daft like that.
Help appreciated.
Regards Simon.
flak monkey
posted on 10/5/05 at 08:10 PM Reply With Quote
You need to have it set up so the front wheels lock before the rears.
IIRC the bar also need to be locked with pins, ie it muct look like its permanently locked.
Sera
http://www.motosera.com
Petemate
posted on 11/5/05 at 08:37 AM Reply With Quote
Hi All
Yes, the balance bar set-up has to be locked with roll pins. Wire-locking is not regarded as permanent enough.
HTH
Petemate
BMF
posted on 11/5/05 at 08:55 AM Reply With Quote
Where do you get these roll pins from?
flak monkey
posted on 11/5/05 at 08:57 AM Reply With Quote
An industrial fastenings place should have them in pretty much any size. Take a look in the Yellow Pages for a local one.
Also things like this are available (though you wouldnt wat to buy all that!):
http://www.diytools.co.uk/diy/Main/Product.asp?iProductID=29409
Sera
AvonBelgium
posted on 11/5/05 at 01:22 PM Reply With Quote
Any sugestions about how to set up this without driving the car ?
evo3500
posted on 11/5/05 at 06:20 PM Reply With Quote
Thanks for the input,so what you are saying is to drill the threaded section on each side of the bearing and put a roll pin in so the nuts cant be adjusted,am i understanding this correctly,if so can slit pins be used instead ?
evo3500
posted on 11/5/05 at 06:22 PM Reply With Quote
forgot to mention does the roll pin have to go through the nut and threaded bar ?
Thanks Simon.
posted on 11/5/05 at 06:54 PM Reply With Quote
Can't really be set without slow speed road testing --- needs to be set up on good dry surface. Usually warnings about starting with excess front brakes then gradual turn towards the rear untill all 4 whhels lock at the same time -- from SVA purposes turn back 2 full turns towards the front.
Also check the clearance between the yokes and the pedal tube isn't excessive say 0.5mm to .7mm. Too much clearance and it won't function in the even of a circuit failure to little and it won't act as a balance bar.
If you have too much rear brakes the balance point is way off centre fit a bigger master cyl;inder to the rear circuit than that on the front.
[Edited on 11/5/05 by britishtrident]
