Author: Subject: Avon Suspension
AvonBelgium
posted on 15/5/05 at 10:47 PM Reply With Quote
Avon Suspension
A question for those that finished there Avon
Where you able to get the suspension aligment correct ?
And what about total weight ( in kg please) ?
Avoneer
posted on 16/5/05 at 11:01 AM Reply With Quote
Mine weighed in at 636kg, but I had a lot of extra bracing in the back.
Never had the suspension done properly, but I'm sure they would struggle due to the bad geometary.
Pat...
Lightning
posted on 17/5/05 at 08:46 AM Reply With Quote
Mine was 460Kg but with a bike engine.
Had the geometry chacked, which averaged about 1 degree out everywhere. Managed to get all adjusted exept for one side at the rear which stilll is .5 degree out. Going to try and adjust it again now the suspension has time to settle.
Northy
posted on 17/5/05 at 07:46 PM Reply With Quote
Lightning,
How much difference did it make having the suspension set-up better?
Pat,
Are you wanting to ever sell your car?
Graham
Lightning
posted on 17/5/05 at 09:17 PM Reply With Quote
It now goes in a straight line........ I jest not. Initially it had a tendancy to wander at high speed and you could not let go of the wheel as any deviation in the road would unstable the car. Even on the flattest of roads
Now its stable at max speed with minimal grip on the steering wheel.
Going on a track day in 3 weeks, let you know how in corners. Too many big trees and ditches around here to push too hard.
However I did touch 115mph on the country road back from Plymouth today. What a screem Overtaking is a blast as well usually 2 or 3 at a time. I must grow up one day........naarrr.
