New Topic New Reply
Author: Subject: Propshaft pics
hearnia
posted on 16/5/05 at 06:47 PM Reply With Quote
Propshaft pics
Has anyone got any pics of how they have mounted the propshaft to the side of the wheel well please? Its the next stage and I'm a bit stuck. Also what thread bolts go into the diff end that mates with the prop?
joe
alister667
posted on 16/5/05 at 07:16 PM Reply With Quote
I hope I understand you right. Here's a pic of my carrier bearing.
I found a large lump of box section iron and used it as a spacer to keep the carrier bearing out from the side of the tranny tunnel a bit. I assume this is what you mean when you say wheel well? Perhaps you mean foot well? I hope my pic explains better than I do!!
For the diff / prop question read THIS thread.
All the best
Ali
http://members.lycos.co.uk/alister667/
hearnia
posted on 16/5/05 at 07:21 PM Reply With Quote
yeah thats what I meant sorry, its been a long day Cheers for the pic, that was similar to what I was thinking of doing.
posted on 16/5/05 at 08:42 PM Reply With Quote
In our website.... ermmmm
hErE yOu gO
HTH
dnmalc
posted on 16/5/05 at 09:11 PM Reply With Quote
Is it realy necessary to use the support? I was considering using a 1 piece prop from the rubber donut to the diff and junking the bearing. This will have the advantage of loosing wieght and complexity
Avoneer
posted on 16/5/05 at 10:04 PM Reply With Quote
That would be fine with a car engine, but a central bearing is required with a bike engine due to the incresed length of the prop shaft.
Alister - where did you get your prop from. I need one like that with a telescopic section between the diff and the central bearing due to my live axle.
Pat...
alister667
posted on 16/5/05 at 10:32 PM Reply With Quote
A crowd in Newry, Northern Ireland called Gregory Propshafts.
AFAIK he's not too keen on doing sports car props, most of his work seems to be agricultural / lorry related, but his work is of a good quality. A guy I know with a Westfield had his made up by there and recommended him.
As for the mainland I'd guess you might contact Bailey Morris for a custom propshaft?
alister667
posted on 16/5/05 at 10:38 PM Reply With Quote
MK use a 'slider' up at the front of thier diffs, mine has a very similar arrangment up front, I suspect yours could use one at the front and one at the back?
Under the gearstick in the pic the rubber gator isn't covering a slider - it's put on to cover the 2 piece makeup of my prop - it has an inner sleeve mated to a rubber lining which is bonded to the outside which is connected to the diff. This give a slight 'cush' drive effect - supposed to be easier on the gearbox, and less 'clunky' - again it was recommended to me by other much more knowledgable folks and seems to work fine. Mind you it's still as clunky as hell!
New Topic New Reply
