New Topic New Reply
Author: Subject: no self centering action
evo3500
posted on 24/5/05 at 09:47 PM Reply With Quote
Sva next week noted no self centering action when i drove the car to mot anyone have any suggestion for set up,its a gt1
it differs slightly from oringinal as has an escort mk 2 quik rack mounted higher than oringinal narrowed sierra item,also track rods go through top of steering arm,previously went through under side,any advice or thoughts on best set up to get some self centering appreciated
Thanks Simon
posted on 24/5/05 at 10:01 PM Reply With Quote
I can't remember which it is, but a healthy dose of toe in/out should give some self centre effect. Also does the GT1 use the Sierra front uprights, with MK's adapter like the Indy? If so have you got the castor angle set to the maximum available?
Good luck with SVA - car looks very good!
Nick
evo3500
posted on 24/5/05 at 10:11 PM Reply With Quote
Thanks for the reply it does have the same set up virtually as the indy it does use the sierra upright with the mk adaptor.
thanks Simon
dnmalc
posted on 24/5/05 at 10:18 PM Reply With Quote
I am not sure Nick 205 is correct as I was under the impression that it was the castor angle that was the lagest self centring force
rayward
posted on 24/5/05 at 10:41 PM Reply With Quote
Caster angle normally takes care of the self centering, but as its sometimes hard to alter this, toe out will give some self centering effect for the SVA, the more the better, but remember to adjust it back afterwards or it will trash your tyres.
Lowering your tyre pressures may help too.
Ray
posted on 25/5/05 at 06:44 AM Reply With Quote
Tyre presures lower = more self centering
DarrenW
posted on 25/5/05 at 08:13 AM Reply With Quote
1-2 degrees toe out, max castor and 40psi will give self centering.
Tyre pressures defo better higher for SVA - reduces contact patch and resultant friction.
evo3500
posted on 25/5/05 at 08:09 PM Reply With Quote
Thanks for the info will give it a try 40psi toe out and max castor.
and sneak a quick run around the block.
Regards Simon.
New Topic New Reply
