Author: Subject: trim under dash area
evo3500
posted on 24/5/05 at 09:57 PM Reply With Quote
for sva do you have to have the area above your legs / under dash paneled in or not also what radius is required on lower edge of dash.
Thanks Simon.
tri
posted on 24/5/05 at 10:04 PM Reply With Quote
of what i understand you do not need to put anything in there
Tri
donut
posted on 24/5/05 at 11:11 PM Reply With Quote
I didn't and it was ok. I think as long as theres nothing hanging and everything is tidy and secure it should be ok.
[Edited on 24/5/05 by donut]
Mike S
posted on 25/5/05 at 07:44 AM Reply With Quote
Simon
According to SVA Manual, if dash is padded bottom radius must be 5mm minimum. If unpadded, then radius must be 19mm minimum.
Mike
There are more horses' asses in this world than there are horses
posted on 25/5/05 at 07:46 AM Reply With Quote
And if you pad it, you shouldn't be able to feel the edge underneath if you push the padding hard with your thumb.
evo3500
posted on 25/5/05 at 07:59 PM Reply With Quote
Thanks for the advice will let you know how i get on after sva on tuesday .
Thanks Simon
