Author: Subject: T piece on Blade carbs
MAB
posted on 21/6/05 at 11:24 AM Reply With Quote
Wanted please - fuel T peice off Blade RRT carbs!
I have a problem in that one of the brown T-pieces that connect between the carb float chambers and onto one of the fuel pipes has cracked into several pieces.....
Does anyone have a spare one they would be prepared to sell please?
Alternatively - does anyone have a cheap set of blade carbs at a reasonable price that I could dismantle and use the T-piece? - I've checked Ebay but nothing available in the next couple of days...
Many thanks, - Mark.
shortie
posted on 21/6/05 at 11:32 AM Reply With Quote
You could always try superglue
MAB
posted on 21/6/05 at 11:49 AM Reply With Quote
As you know Mr short - I did! - and it got me to Beverley to get it registered! - however I would now like to drive around safely!
But thanks for the humour!
Regards, Mark.
welderman
posted on 21/6/05 at 02:50 PM Reply With Quote
Could be bad news mate. Same happened to me and local breaker had non. Honda wanted 14.99 for a new one. So thats what i ended up with. Happy huntin.
posted on 21/6/05 at 05:11 PM Reply With Quote
Could you get 6mm or 8mm solder ring fitting to fit in there. They use them on microbore plumbing so a good supplier should carry them and they'd be less than £14.99.
MAB
posted on 21/6/05 at 06:52 PM Reply With Quote
Thanks for the suggestions guys...
I've spoken to local Honda dealer who wants £19.99 & P&P for one!
.....however their main supplier doesn't have any and is quoting 10 days + for delivery!!!
Waiting 10 days after only passing SVA and registering car 4 days ago could be difficult!
Local dealer was also suggesting that the T peices are specific to the year of manufacture of the carbs etc- not sure I buy this because they all look pretty much the same even if different years have different part numbers etc! - oh well - I'll have to wait!
Regards, Mark
posted on 22/6/05 at 12:13 AM Reply With Quote
Bad ;uck - but it's not long to wait - really!!
andyharding
posted on 5/6/06 at 01:15 PM Reply With Quote
Anyone come up with a locost solution to this problem? Picked a set of carbs up on eBay and one of the Ts is broken. The carbs were only £19 so not worth £19.99 for a new one!
