ADD
posted on 21/6/05 at 05:37 PM |
Best handling 7
Is there a clear winner out there for best handling 7 style car?
Any input would be helpfull, I am interested in a good handling cars' set up to base mine on.
andy d (rizla)
posted on 21/6/05 at 06:38 PM |
no such thing as a better handling seven than another,its all down to the correct geometry set up and suspention and tyres and brakes etc etc
each is made by the builder to suit them
if you watch F1 BOTH SHOEMAKER AND BARRAKELO drive ferraries but both have them set up differently for the same track and condition
ps. my vortx is the nuts in the handling department![](/images//smilies/bigsmile.gif)
sorry couldnt resist![](/images//smilies/bigsmile.gif)
smart51
posted on 21/6/05 at 07:00 PM |
... but different wishbone lengths and angles will alter the camber control significantly. You can set up static camber and toe very finely but
that's only half the story.
Also, don't some have live axles, some De Dion and some IRS? surely that will affect the handling?
mandbsheldon
posted on 21/6/05 at 07:22 PM |
MK Indy![](/images//smilies/tongue.gif)
andy d (rizla)
posted on 21/6/05 at 07:28 PM |
to a certain extent yes,it will make a difference,but some drivers prefer live axels,some prefer indipendant suspention,
its down to personal choice,and what suits your driving style
its easier to mod a car to the driver but its very hard to mod the driver to the car
mookaloid
posted on 21/6/05 at 07:46 PM |
I believe the Stryker is generally thought to be one of the very best and is often at the front in mixed make racing or sprints/hill climbs.
Maybe there are fundamental design reasons for this but I'm not sure.
Mark
ned
posted on 22/6/05 at 12:11 AM |
i would rate the striker highly, race results speak for themselves imho, it has track pedigree.
Ned.
beware, I've got yellow skin
PAUL FISHER
posted on 22/6/05 at 12:24 AM |
no,your all wrong,its the MK INDY!![](/images//smilies/wink.gif)
bimbleuk
posted on 22/6/05 at 07:10 AM |
I'm biased to the Striker because I have one
It was however one of the first designs to incorporate things such as inboard suspension and offset engine location. Its also quite compact and light
even in the kit car world.
As for IRS or Live axle. Well both can be equally as good but IRS tends to give better ride quality on road and Live axle works well on a smooth track
surface.
DarrenW
posted on 22/6/05 at 08:17 AM |
The Mac#1 ZR has good handling. Helped a lot by better weight distribution as the engine mounts are further back - less weight over the front end
etc.
At the end of the day they are all custom built so its down to build spec, set up and driver skill. I doubt many people have the opportunity to back
to back several cars with similar set ups to make the comparison.
carnut
posted on 22/6/05 at 10:32 AM |
All very well moving the engine mounts back on a pinto engined car but if you do it with a bec, you end up with a massive weight bias towards the
rear.
stressy
posted on 22/6/05 at 12:02 PM |
in General as a "jump in and drive" then in my opinion a caterham
a or a "well set up" westie. I was quite impressed by the striker tho a bit too stiff for my tastes.
WHO DARES SPINS
