Author: Subject: LED lights - SVA OK?
RazMan
posted on 25/6/05 at 10:58 PM Reply With Quote
This little numberplate light looks really neat, but is it ok for SVA?
[Edited on 25-6-05 by RazMan]
Raz
posted on 25/6/05 at 11:01 PM Reply With Quote
Cool.
No idea about fit for purpose though... give em a call and find out!
RazMan
posted on 25/6/05 at 11:06 PM Reply With Quote
If I understand 'fit for purpose' correctly, it has basically got to light up the numberplate. E marking doesn't seem to be required then?
Raz
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
Building: Haynes roaster in college with students, gulp!
posted on 26/6/05 at 09:20 AM Reply With Quote
mot states that it should be white. Any compulasy lights must be the correct colour, but additional lights do not come into it e.g. boy racer blue washer jets.
RazMan
posted on 26/6/05 at 09:27 AM Reply With Quote
Aha - so as these led's are actually white in colour they should be ok
Raz
Steve @ sVc
posted on 29/6/05 at 11:37 AM Reply With Quote
Number plate lights should give "adequate" illumination, so it’s up to the tester (if the light is not "E" marked) to say if he thinks its adequate or not.
Careful about bolt or screw heads with less than 2.5 mm rads.
Regards
Steve @ sVc
posted on 29/6/05 at 12:35 PM Reply With Quote
They test it in daylight without a plate fitted. If it shines and it's not got sharp edges it passes.
RazMan
posted on 29/6/05 at 07:19 PM Reply With Quote
Raz
