Author: Subject: Which Motorcycle Throttle bodies r the best
TVR_3000MTURBO
posted on 29/6/05 at 10:48 AM Reply With Quote
Hi all, I am currantly building a luego velocity using the 1.6 ford sigma engine with cams, Im hoping for 170bhp+ with an emerald ecu but need to no what throttle bodies to use. GSX1000/1100/r1/r6
ect. Does anyone have any sudjestions, Also has anyone completed the convertion because i have heard that the return angle of the butterfly is greater than car Throttle bodies and can cause poor idle,
Thanks Guys
Stuart
stevebubs
posted on 29/6/05 at 11:48 AM Reply With Quote
Thanks Guys
Stuart
GSXR 750 and 1000 bodies should be fine. 600s may also work well (they're a bit smaller.
No problems with idle on my car.
TVR_3000MTURBO
posted on 29/6/05 at 12:04 PM Reply With Quote
what size engine are you running, Did you get it set up by Dave Walker. What BHP is she running at.
Stuart
stevebubs
posted on 29/6/05 at 06:18 PM Reply With Quote
2 litre blacktop zetec.
Not setup by Dave Walker. In fact, not setup properly at all yet - still getting the gremlins out of the machinery before I map it properly
<--- Pic of the install
[Edited on 29/6/05 by stevebubs]
