Author: Subject: speedo healer
pifular
posted on 1/7/05 at 04:24 PM Reply With Quote
speedo healer
thinking of buying a speedo healer, any one got any experience good or bad. want to use on a MK indy with honda blackbird engine and clocks.
posted on 1/7/05 at 04:36 PM Reply With Quote
brilliant tool!
Better than the Yellow Box...
subk2002
posted on 1/7/05 at 04:40 PM Reply With Quote
Superb!! Go for it
wilkingj
posted on 1/7/05 at 06:41 PM Reply With Quote
Uhhh Wot ???
Err what does it do?
Best Regards
Geoff
http://www.v8viento.co.uk
tks
posted on 1/7/05 at 06:47 PM Reply With Quote
Wouldn't do it
go the locost way
build it your self..
and learn something..
posted the needed materials earlier in another post.
what does it costs??
for 7pounds i make you one, but you need to make an case for it.
Tks
what it does??
its just a PWM devider or multiplyer..
[Edited on 1/7/05 by tks]
posted on 1/7/05 at 07:32 PM Reply With Quote
Geoff
A small device for recalibrating or 'exacting' out your speedo. Has a range of (IIRC) +-200%. It also converts mph to kph and has a top speed memory retainer. It's pretty water resistant and guaranteed for two years. It plugs straight into the existing connections. It's also relatively cheap compared to other alternatives.
HTH
tks
posted on 1/7/05 at 08:13 PM Reply With Quote
speedohealer
no every one will need that device??
think that many know enough with just an corrected speed?
Tks....
posted on 1/7/05 at 09:29 PM Reply With Quote
When I say recalibrating, what i guess I mean is alters the ratio of input to output with simple dip switches. + and - it's very easy to achieve almost zero error. Plus if you change your wheels or tyres periphery, a simple 1-2 minute change is all it takes to alter it.
pifular
posted on 1/7/05 at 10:23 PM Reply With Quote
thanks for that, your comments give me enough confidence to order it. may be back on here for advice during set up. thanks again.
