troid
posted on 10/7/05 at 03:22 PM |
pedal box
hi all
has anyone got any pictures of their pedal box assy using mk2 escort pedal or has anyone got any ideas to make this job alot easier
thanks
Avoneer
posted on 10/7/05 at 04:01 PM |
I found MK's is probably the best/easiest/simplist and best value for money as it uses the Sierra master cylinder.
Have a search for "best pedal box".
Hope that helps,
Pat...
clbarclay
posted on 10/7/05 at 04:33 PM |
MK pedal box can also be used with an escort MC. As for simplest probably yes, but as for easiest, I doubt it because the kit comes in 4 components
each having to be welded to the chassis seperatly. Compare this to may pedal box assemblys that come as one complete unit that can be bolted or welded
to the chassis.
troid
posted on 10/7/05 at 05:54 PM |
I dont want to sound stupid but is may a name of a manufactoer as im using escort master cylinder?
Avoneer
posted on 10/7/05 at 06:19 PM |
Do you mean MK?
If so, yes it is a manafacturer.
Pat...
troid
posted on 10/7/05 at 08:06 PM |
once again thanks all
gonna go for the mk one that bolts to the floor looks spot one
Steve Hnz
posted on 14/7/05 at 11:36 AM |
quote: Originally posted by clbarclay
Compare this to may pedal box assemblys that come as one complete unit that can be bolted or welded to the chassis.
I'm picking that
"may" was sposed to read "many" in which case it would make more sense in this context.I Think! Cheers, Steve.
