escary
posted on 12/7/05 at 08:11 PM |
pedal assemblies
complete , dismantled or even a drawing
ideas, photos
even a clue as to what you guys used.
Building book locost, can get sierra parts without too many probs, or could use Mk2 escort master.
Too tight to buy a set from MK ( I'm Scottish )as they are 80 quids, or 8 rounds at the bar which ever mood you're in at the time .
Hope you can help.
Regards
Ewan
posted on 12/7/05 at 08:19 PM |
i used regular chassis tubes to make the pedals, 25x3mm flat to make folded brackets and the foot rests. Welded each to the chassis direct. A sierra
master cylinder operated by a simple rod on a swivel, the throttle and clutch cables i just bodged on. Very easy really. Cost was a few hours and
about a pound of metal!
RazMan
posted on 12/7/05 at 10:24 PM |
This might be useful...
http://www.locostbuilders.co.uk/viewthread.php?tid=28649
Raz
DavidM
posted on 12/7/05 at 10:52 PM |
I used the complete pedal assembly from my Escort donor mounted in a new pedal box fabricated from 2 mm thick steel. All geometry, pedal positions and
pedal throws are the same as the Escort.
Pictures in my archive.
Proportion is Everything
Paul Ash
posted on 13/7/05 at 06:18 AM |
I have one for sale
Pedal box for sale
£50
Hornet
posted on 13/7/05 at 07:19 AM |
I used escort master cylinder (and Servo.. big jessie) and made up pedals from escort ones. I can nip down and let you see them if u want dood...
Cheers John
