Author: Subject: HT lead extending...
jambojeef
posted on 14/7/05 at 12:18 PM Reply With Quote
Hello,
Want my coils to sit on the bulkhead shelf but the I need longer HT leads - who does these? I might also need new CBR 1000 coils since mine are a bit broken!
cheers
Geoff
chrisf
posted on 14/7/05 at 12:55 PM Reply With Quote
I have standard 98 'blade coils that you can have for some beer money + post (from the USA ) if you're interested. I have no idea if they will work for your application or not.
--Let me know, Chris
adam_moore
posted on 14/7/05 at 03:33 PM Reply With Quote
I extended my fireblade coils myself (as many others have).
I pulled the existing lead from the cap and unscrewed the other end from the coil and replaced with a longer length of cable. I used silicone cable that I got from VWP (very flexible stuff) and it was easy to get a good connection...they worked first time.
don't forget to reuse the olive on the coil end of the HT cable and use it on the new assembly.
There's a picture of the leads in my archive...can't figure out how to past pictures into a post?
[Edited on 9/8/05 by adam_moore]
jambojeef
posted on 15/7/05 at 08:34 AM Reply With Quote
Hi adam,
Cool idea but couldnt find the picture in your archive - would like to have a look though if there is a picture around?
Geoff
jambojeef
posted on 21/8/05 at 09:48 PM Reply With Quote
Hey Adam,
Cheers for the suggestion!
Lead arrived from VWP and all made up in double quick time!
Cheers for that - they work and look spot on
Geoff
