Author: Subject: Brake fluid level
ChrisW
posted on 20/7/05 at 07:39 PM Reply With Quote
Brake fluid level
I'm pretty sure I know the answer to this, but just to check....
Do you have to have a brake fluid level warning to pass SVA?
Chris
Deckman001
posted on 20/7/05 at 08:09 PM Reply With Quote
Yes, the type with a push button on it !!
Jason
Surrey Dave
posted on 20/7/05 at 08:49 PM Reply With Quote
I wired in a separate little switch , that you push to test the warning light ,is that not still allowed?
Petemate
posted on 20/7/05 at 09:01 PM Reply With Quote
That's fine. The usual method is for the warning light to be activated by the handbrake via a switch, but a push button is OK. Whatever turns you on... (sorry for the pun....)
Petemate
posted on 21/7/05 at 07:27 AM Reply With Quote
"Think I may have lost my slot... "
That can make your eyes water!
NS Dev
posted on 21/7/05 at 08:30 AM Reply With Quote
It doesn't have to have a button on it. There needs to be a method of testing the warning light (as was said, most use the handbrake, that's what I'm doing and what 99% of road cars do)
Deckman001
posted on 21/7/05 at 09:54 AM Reply With Quote
EEK, sorry if my post was misleading, you do need a fluid level warning !! but a separate switch or button will suffice to test the circuit, as said , the normal test is via the handbrake/ or a button on the reservoir
Jason
ChrisW
posted on 22/7/05 at 05:48 PM Reply With Quote
That's what I thought. What are people using for reservoirs then?
I'd like to use something like this...
http://www.rallydesign.co.uk/catalog/product_info.php?products_id=4055
..but obviously it has no level switch. I have a Luego twin output jobbie but I'm not too happy with the weight of the feed tube on the plastic fittings.
Chris
Paul (Notts)
posted on 22/7/05 at 06:31 PM Reply With Quote
Europa Spares do a dual feed SVA compliant res but its a bit pricey.
http://www.europaspares.com/
[Edited on 22/7/05 by Paul (Notts)]
theconrodkid
posted on 22/7/05 at 07:03 PM Reply With Quote
chris,there are some lids in the barn,plastic box near the door,ps any joy with the washing machine?
who cares who wins
pass the pork pies
ChrisW
posted on 25/7/05 at 07:10 PM Reply With Quote
Barn has all been cleared up since the stuff was by the door! I take it they are standard lids though - will they fit the single reservoirs?
Chris
