Author: Subject: pics
lenny
posted on 24/7/05 at 01:35 PM Reply With Quote
pics
lenny
posted on 24/7/05 at 01:36 PM Reply With Quote
lenny
lenny
posted on 24/7/05 at 01:37 PM Reply With Quote
antonyg
posted on 24/7/05 at 01:43 PM Reply With Quote
Hi, car looks good
where did you get that bonnet bulge from or is it home made iam after one just like tha for mine
Thanks Antony
lenny
posted on 24/7/05 at 01:47 PM Reply With Quote
MK Bonnet
chrisf
posted on 24/7/05 at 01:50 PM Reply With Quote
Lenny:
Top job! I just finished my dash too (see website). I like the way you set your gauges cluster in the dash. How did you secure the cluster to the dash? I haven't quite figured out how this is done.
Also, it looks like you have a bit of trim around the cluster itself. Is that just tadpole trim?
Again, I like it. Looks really well done.
--Chris
lenny
posted on 24/7/05 at 01:58 PM Reply With Quote
Clocks , split in half take out PCB and drill back of case and glass in some domehead and refit then a lot of cut and try then glass in a plate to set clocks back how you like them , yes edge trim all round Lenny
lenny
posted on 24/7/05 at 02:10 PM Reply With Quote
MikeR
posted on 25/7/05 at 11:22 AM Reply With Quote
probably not understanding the last image correctly but it looks like your rad vents directly onto the cooling fan of some compondent..........
might be an idea to fit a rubber tube to direct the water somewhere else.
