Berracvh
posted on 26/7/05 at 09:56 AM |
Cbr1000 clutch problem in locost
I cant get the clutch to disengage , the clutch rod moves 7mm , anyone knows how long it should move ?
/Johan
tks
posted on 26/7/05 at 12:08 PM |
how do you know it moves??
i bet that its an air lock...
fill the system up to max...
and just waist allot of fluid with an automatic fluid sucker on the niple of the slave cilinder.
also i could take air out of master cilinder
by moving the lever away from me, instead of in de direcion of the bar...
Tks
the problem is that if there is no force needed it al works but when you need to allot of force the small bubles compress
the best way to work with it is with the clutch in the air (sow you can see that it moves/the basket etc...)
Also you have to take in mind thats an wet clutch system that means that just disengageing doesn't work sweet..
i needed at minimum gear in 4 to turn with my hand the basket and the first time
more force is needed..
Berracvh
posted on 26/7/05 at 03:04 PM |
Ok
Didnt know that about wetclutch , maybe im not so far off , will try with 4th gear.
/Johan
