New Topic New Reply
Author: Subject: Mig or Tig
Lotusmark2
posted on 27/7/05 at 07:44 PM Reply With Quote
Mig or Tig
OK guys will be doing some modification and repairing of my formula chassis and was going to use my 115A mig but a welder friend of mine has said "ya need to TIG that mate, migs no f****ing good for chassis"
so as far as I know most of you weld with mig so thought I would ask for opinions.
Avoneer
posted on 27/7/05 at 08:04 PM Reply With Quote
As far as I am aware, either will be fine.
I have heard of chassis' done both ways with no long term problems.
Both mine are mig'd with some bits tig'd.
Pat...
posted on 27/7/05 at 08:18 PM Reply With Quote
As long as the welder and your welding are upto the job either will be fine. If your mate is a welder with decent kit, why not tap him up to do it for you
Nick
mark chandler
posted on 27/7/05 at 08:32 PM Reply With Quote
TIG is king minimal distortion and very clean, that said MIG is twice as fast
Make sure you really burn into the metal, its easy to get a good looking MIG weld that sits on top of the work, the biggest mistake is to hurry and not use enough current, most importantly clean work and clean wire, not wire thats gone rusty in you MIG welder as its sat in the garage !
Lotusmark2
he is an ex loyds coded welder but not the most reliable person in the world
kb58
posted on 28/7/05 at 12:37 AM Reply With Quote
An AC/DC TIG is very versatile and very clean, no weld spatter, no smoke. You can weld steel, stainless, aluminum, anything you need. It isn't cheap though. To answer your question, for mild steel either will work fine assuming the operator is competent.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
want2race
posted on 28/7/05 at 03:20 AM Reply With Quote
Your friends full of it mate!
The reality is that both will achieve full penetration into the metal if used properly. And realistically an untrained person would be much better off with MIg than trying to use a TIg off the bat. The bottom line is you will be damn good by the end of the project when you no longer need the skill
Lotusmark2
posted on 28/7/05 at 05:27 AM Reply With Quote
Thanks guys, confirmed my own thoughts on this, puts my mind at rest as I am not about to shell out big bucks on a TIG when I have a MIG sitting there
posted on 28/7/05 at 09:54 AM Reply With Quote
I'd better tell the lads at MK and MAC1#, GTS and all the rest to stop doing it wrong straight away. Coded welders don't usually weld 16g material used in chassis and I've seen some of them struggle to do it as well as a shed mechanic who does most of his work in lighter metal.
Alan B
posted on 28/7/05 at 01:53 PM Reply With Quote
Originally posted by Peteff
I'd better tell the lads at MK and MAC1#, GTS and all the rest to stop doing it wrong straight away.............. quote]
Don't forget TVR, and more than likely Ferrari and Lamborghini......I know TVRs are migged and pretty certain about the other two also......
James
posted on 28/7/05 at 02:30 PM Reply With Quote
Are Ferrari/Lambo not carbon by now?
Talk about stuck in the dark ages!
I want a DB9 (carbon???) anyway!
James
Alan B
posted on 28/7/05 at 02:54 PM Reply With Quote
James
Yeah, I'm sure some of the current models are.....I'm thinking of slighty older models with spaceframes of course...
posted on 28/7/05 at 05:53 PM Reply With Quote
Check the chassis isn't brazed -- that was the tradditional way of building spaceframes.
If it is brazed joints best use brazing/bronze welding for any mods or repairs.
New Topic New Reply
