Sideways
posted on 2/8/05 at 09:37 AM |
sierra rear diff with LSD, which models??
did any sierra's come with a decent lsd? thinking of fitting one to my future build.
cheers
0-60 in 14 seconds, time to start a build i guess!
James
posted on 2/8/05 at 10:55 AM |
4x4s all did and they are mostly, if not all, disc braked.
James
- Muhammad Ali
ChrisW
posted on 2/8/05 at 12:04 PM |
They are all disc braked. Also the XR4 and some Scorpios had LSD I believe. The Scorpio diff is 0.5" (making it 7.5" wider across the
mounts though.
Chris
DarrenW
posted on 2/8/05 at 12:27 PM |
For some reason the text on your last reply was unreadable.........nice avatar!!
Sideways
posted on 2/8/05 at 02:25 PM |
cheers guys
posted on 2/8/05 at 06:06 PM |
to my (limited) knowledge, xr4s are not fitted with LSDs. Only 4wd and some (all?) 2wd cossies.
mookaloid
posted on 2/8/05 at 07:33 PM |
Correct
posted on 2/8/05 at 07:44 PM |
lovely i was fairly sure but i do detest posting misinformation!
the_fbi
posted on 2/8/05 at 08:21 PM |
Correct
Hm... So both these sellers are wrong?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4566046105
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4565588333
mookaloid
posted on 2/8/05 at 08:31 PM |
The XR4i (2wd) has push in drive shafts with 10" drum brakes. ratio 3.62 non LSD
The Xr4x4's had lobro (bolt on shafts) as in the 2 on ebay the ratios were 3.62 except the 2.0i which had a 3.92 both LSD
The LSD was also fitted to the 4x4 Ghia
I can only assume that the ebayers are abbreviating XR4x4 to XR4...
Mark
Unless someone can prove me wrong...
mookaloid
posted on 2/8/05 at 08:38 PM |
cheers
Just looking at the original question: are they a decent LSD?
I have some experience of the diff in action and I was a little concerned at the 'grabby' nature of the engagement of the limited slip. I
now understand that in order to engage the limited slip bit it has to experience some wheel spin first. This means that there is a short period of
time when the wheel starts to spin, then as the limited slip bit kicks in a disconcerting sudden increase in grip occurs which does not always lead to
smooth cornering. I am now considering a Quaife ATB
Mark
the_fbi
posted on 2/8/05 at 08:40 PM |
Thanks for clearing that up Mark. I'm hoping to get one of those 2 and didn't want to end up with a pup.
ta
Chris
posted on 3/8/05 at 07:29 AM |
the second one says its from an 4x4 anyway
Sideways
posted on 3/8/05 at 12:20 PM |
cheers mookaloid, sounds like it may not be the best option for a nice light kitcar, could upset the handling somewhat mid corner, I seem to remember
driving a 2L 4x4 sierra that would spin a little before powering out of a corner (if powering isn't too strong a word for a sierra!! ) I guess
it will be worse being 2wd rather than 4wd as well.... hmmmm
ah well cheers anyway guys
mookaloid
posted on 5/8/05 at 09:22 PM |
Get both open and LSD and give them a try, they are easy to swap and you can choose which one you like best
Mark
RichB
posted on 16/8/05 at 12:37 PM |
Sorry to add to the post but which of the ratios is preferable? I have also heard of people using the diff from a freelander - is this a better unit
to use if available?
Rich
ned
posted on 16/8/05 at 12:54 PM |
try the quaife speed calculator:
http://www.quaife.co.uk/products/gearboxes.htm
beware, I've got yellow skin
Liam
posted on 19/8/05 at 10:37 PM |
The freelander diff is nice and light, but not an lsd. Only option for a lsd freelander diff is a big cheque to quaife.
Liam
ned
posted on 19/8/05 at 10:57 PM |
there was also a gls 4x4 sierra iirc and i think i've seen one!
Ned.
