Ben Smith
posted on 2/8/05 at 11:04 PM |
Any Electrical Wizards out there?
Recently bought 2 Aim ST1 dashes off Ebay. One of these is complete the other is not! The plan was to copy the wiring from one for the other.
Unfotunatley the entire plug is missing from the incomplete unit. In the manual this is described as a 26 pin M/S connector. After doing a little
research it apears to be a French military radio connector of some sort. It is a two piece plug with a bayonet connection.
I think I can get one but at great expense (nearly£100![](/images//smilies/shocked.gif) ).
Any body know a cheaper solution?
Will post a couple of pic in archive tomorrow. Would be a shame not to get it working . Is exactly what I want.
Ben.
scutter
posted on 3/8/05 at 06:32 AM |
Ben can you get a picture? if so I may be able to borrow one from work
ATB Dan.
dickieboy
posted on 3/8/05 at 07:51 AM |
Try a company called RS, they have all sorts of things like that.
Ben Smith
posted on 3/8/05 at 10:59 AM |
UPDATE.
Have managed to get a prewired loom half of this plug from DATASPARES. He can get the other half but will be £41, min of 4 ordered and 12 weeks .
I have posted a couple of pics in my archive. It is the half that fits to the unit that I need. With a bayonet fitting to match the half I have
coming.
I will post a pic of the loom part when it arrives.
Ben.
Mix
posted on 3/8/05 at 11:24 AM |
From your photo it looks like you are missing the housing from a bulkhead connection. The rubber housing with the sockets in it would normally
protrude through the panel and be retained in the housing which also incorporates the bayonet fitting. If this is the type of connector I think it is
you will need to get the part number of the plug as the plug and sockets have indexing keyways
stevebubs
posted on 3/8/05 at 12:03 PM |
Ben,
Put a request out on the Sylva list. There's a few people on there who may be able to locate the part
Stephen
Ben Smith
posted on 3/8/05 at 12:06 PM |
Have now got the part number for the half that is fixed to the unit that I need.
85102E16-26S50-16
I HAVE NOW PUT A PIC OF THE LOOM PART OF THE PLUG IN ARCHIVE. JUST NEED THE OTHER HALF!!
[Edited on 4/8/05 by Ben Smith]
rayward
posted on 10/8/05 at 09:16 PM |
from http://www.rswww.com
search for 26 way connector
example pics, they list
26 way chassis mount plug
26 way chassis mount socket
26 way cable mount plug
26 way cable mount socket
you may just have to ring them to clarify which half they class as plug and which as socket.
cost £20 - £30
[Edited on 10/8/05 by rayward]
Stuart Ainslie
posted on 11/8/05 at 06:22 AM |
Looks like a Litton connector or another variation of that theme..
Try a google search for Litton plugs and see what comes up, may be a bit pricey though..
chriscook
posted on 11/8/05 at 08:11 AM |
You may have to order the contacts to go inside the plug seperately which is what normally pushes the price high.
Chris
Ben Smith
posted on 12/8/05 at 10:16 AM |
Thanks for all your help guys. looks like we'll get there.
Ben.
