richyo
posted on 5/8/05 at 07:54 AM |
Lower column to steering rack
I'm trying to fit my sierra modified lower column to a Mk2 Escort rack. It is TAF.
Are the splines different or is there a way to fit them other than brute force ?
TIA
Richyo
posted on 5/8/05 at 08:45 AM |
you have to fully remove the lockbolt, not just loosen it. Caught me out anyway
posted on 5/8/05 at 10:05 AM |
likewise Joel - I spent a while getting very aggravated until I spotted that ![](/images//smilies/wink.gif)
richyo
posted on 5/8/05 at 12:22 PM |
Thanks guys but the bolt is out and its still tight.
Is there a method to putting it on that I don't know about ?
Any help would be apprecviated as I want to let the car see daylight after 2 &1/2 years and steering would help
Richyo
posted on 5/8/05 at 12:29 PM |
I hammered an old screwdriver into the slot (the one that's closed by the bolt) to widen it a little bit.
This gave me enough leeway to force the thing on and, being tapered, was easy enough to waggle out afterwards.
DJ
posted on 5/8/05 at 01:57 PM |
Likewise with the screwdriver wedge and also make sure you have the shaft extension dead in line with the splined shaft, not at the angle you want it
to finish at.
James
posted on 5/8/05 at 03:31 PM |
There is a 'key' effect with these where some of the splines are filled in on the rack. The blank area has to line up with the split of
the down link.
Make sure you have it the right way round.
Did that make sense?
James
- Muhammad Ali
Dusty
posted on 5/8/05 at 07:59 PM |
Like this. But I think there is a corresponding master slot in the column end as well as the slit.
[Edited on 5/8/05 by Dusty]
![](/galpreviews/a242953-masterspline.jpg) ![Rescued attachment masterspline.jpg](/gallery/a242953-masterspline.jpg) Rescued attachment masterspline.jpg
