Author: Subject: Size of pinto
macintosh
posted on 19/8/05 at 07:40 AM Reply With Quote
Size of pinto
Hello,
does eanyone know size of 2.0 "Pinto" engine?
Specially hight.
jos
posted on 19/8/05 at 07:49 AM Reply With Quote
Not off the top of my head but I will measure mine either at lunchtime or this evening.
No doubt someone will be along soon with the correct information to hand
James
posted on 19/8/05 at 09:31 AM Reply With Quote
Off the top of my head it's 26" (660mm) from rocker box to bottom of sump.
And from that you can chop about 25mm from the sump/oil pickup pipe (maybe slightly more.
If your MCSorley chassis is 2" higher (+442 is 4" longer, 4" wider and 2" taller isn't it?) then you just about be ok with normal Locost height bodywork I think.
HTH,
James
EDIT: I can now *just* clear the cam pulley with a 25mm taller chassis and the GTS bodywork which is about 19mm taller than their Locost stuff.
[Edited on 19/8/05 by James]
wment
posted on 21/8/05 at 04:33 PM Reply With Quote
I ran across a pic showing dimensions for several engines from a locost website. I hope I dont offend anyone by not giving credit but I dont remember where I found it. I have attached it, or tried to attach it below. I hope this helps. If there are any discrepencies please let everyone know. I measured a Mazda Miata (MX-5) at about 23.5" tall.
[Edited on 21/8/05 by wment] Rescued attachment 22R-2.jpeg
macintosh
posted on 22/8/05 at 02:59 PM Reply With Quote
Interesting that your measures and and those in drawings are so different. Hm.
Confused.
NS Dev
posted on 22/8/05 at 03:03 PM Reply With Quote
......and me!
