GTTDi
posted on 25/8/05 at 09:03 PM |
What parts should i buy?
Hi!
im planning on buying a tiger avon chassi and body and built the rest my self.
But my question is does the chassi include the wishbones ? if not what parts should i buy?
I want a chassi with all suspension parts and everything its needed to mount a sierra diff, then i can take it from there
[Edited on 25/8/05 by GTTDi]
Avoneer
posted on 25/8/05 at 09:05 PM |
Buy an MK or a Mac1 - you'll get more for your money, better customer care and a better car at the end.
Pat...
GTTDi
posted on 25/8/05 at 09:11 PM |
where can i find a mac1 type zr stage 1 parts list?
What kind of rear suspension does it use?
viatron
Fairly sure that the avon is available mix n match. ie you can have just the chassis or chassis with wishbones, check out the Tiger website for the
most up to date prices and dont forget www.tigerownersclub.co.uk if you do get an avon!! Building a Phat Cat E1 myself.
Mac
shades
posted on 25/8/05 at 09:19 PM |
the sierra diff will mount straight to the chassi...
As for the corners you'll need top and bottom wishbones. At the rear you will need tiger hub carriers to take the sierra drums and
driveshafts... As discussed above tiger will supply you mix and match bits. For me the customer service has been fine
GTTDi
posted on 25/8/05 at 09:42 PM |
Thanks for the replies!
But i guess my first question should have been if tiger ships abroad??
shades
posted on 25/8/05 at 09:49 PM |
Think they do. When I picked up my kit, in the office they have a map of the world with pins where kits have gone to. There were some obscure places.
Avoneer
posted on 25/8/05 at 11:18 PM |
I'm sure MK ship abroad, as do a few others.
See here: http://www.mksportscars.co.uk/ and here: http://www.mac1motorsports.co.uk/
Personally I think for the money, there are a lot of better kits our there, of better quality and cheaper - I have yet to see an Avon finished for
under £6000.
Tiger have apparantly sold hundreds of Avons (and they said that a few years ago), but I only ever seen 6 finished ones, know of 10 more finished ones
and only know about about 20 all together building/finished.
And don't get me started on the bodywork quality and the wheel arches that are still 1" wider on one side.
Pat...
posted on 26/8/05 at 01:06 AM |
GTTDi - please dont start Pat off.... he's just got rid of his Avon After all the problems he had with ill fitting GRP and arches which were
different widths (all of which are known about and continually reproduced) drives Pat mad However, it's quite funny listening to him
'go-on' about the deficiencies of Avon kits. Personally I like the Avon kits but it sounds like opening a can of worms when you start
building one. The number of Avon owners I know all criticise the build quality... ho-hum!
Andrew Bause
posted on 26/8/05 at 01:45 AM |
Pat, maybe it's time you climbed down of your soap box mate!
For what it's worth, there are satisfied AVON builders out there, I for one am over the moon with mine. Having never built a car before, In my
opinion the AVON build was straight forward and problem free. Tiger's backup and service has been exemplarary - no complaints from me!
Cheers!
Andy Bause
Vauxhall C20XE Powered AVON
[Edited on 26/8/05 by Andrew Bause]
We have been doing so much with so little for so long - Now we can do anything with nothing!
Andrew Bause
posted on 26/8/05 at 01:52 AM |
Hi GTTDi,
I was speaking to Jim Dudley at Tiger a couple of days ago, they have just launched a deal on the AVON body / chasis kit, including front and rear
wishbones, rear hubs and poly-bushes, and ali panel set, priced at around £1,200 might be just what you are looking for ?
Cheers!
Andy Bause
posted on 26/8/05 at 06:55 AM |
Take a long very hard look at the Avon in the cold light of day before ordering --- I was inteterested in one before it became the Tiger Avon but
looking it over I found a lot of aspects that made me very uneasy about it.
The publication of the Avon book also caused a fair bit of contoversey in the forum from builders trying in vain to make sense of the plans in the
book.
It would be fair to say that in this forum you will very rarely see bad things said about the 4 or 5 main Locost(ish) chassis manufacturers, indeed
some you will see nothing but praise for.
viatron
posted on 26/8/05 at 07:33 AM |
Check out the links page at www.tigerownersclub.co.uk there are 3 Avon build diary links there that may make good background reading for you.
Mac
Avoneer
posted on 26/8/05 at 09:36 AM |
Look guys, don't get me wrong, I really loved my Avon and aside from the problems, it was a great car and a good looker.
Just trying to show the other options out there for the same money.
I know several Avon owers that all wish they had built one of the "other" above-mentioned and could have done so for less money.
If I was to show you the letters that I received from Jim when I initially pointed out the problems, I think you'd be suprised.
Right, that's it from me.
Pat...
carlgeldard
posted on 26/8/05 at 12:38 PM |
Ive seen the letter that Jim sent Pat.
(Andrew Bause)
"maybe it's time you climbed down of your soap box mate!"
I think I will have to get you a bigger box Pat.
Carl
GTTDi
posted on 26/8/05 at 03:20 PM |
Andrew Bause - Thanks thats exactly what i want!!
To all others - ALL comments are very appreciated because i live in Portugal and its not possible for me to be at the factory to check the build
quality myself
posted on 26/8/05 at 04:38 PM |
as far as i have observed (i havent done any research though!) MKs maintain the best resale value of the cheaper 7 replicas. This is probably down to
being one of the better known names, with many years and many cars under their collective belt.
This probably isnt relevant to you, i just thought id mention it. However, to a UK buyer, it could be an important factor.
Richard Y
posted on 26/8/05 at 11:39 PM |
also avons are tiny ! i couldnt get in one when a friend brought his round, feet wouldnt get in there, but got in mk's just fine.. bags of
room
things too consider if you not gunna sit in a finished article
andrew.carwithen
posted on 27/8/05 at 11:04 AM |
I too, found with the standard method of installing the 'modified' Sierra pedals, I couldn't get enough leg room in the Avon. But,
having fitted Luego/ST type floor mounted pedals, I'm fine in mine (I'm just over 6' tall and 14 stone).
Lightning is 6' 4" and also fits in his Avon using the same.
Another tip is to panel the front of the drivers footwell on the engine side and the front of the transmission tunnel on the prop side (rather than
the footwell side.) This gives you another 1" length of legroom and width of footroom! (Every little bit helps!)
I like the diminutive proportions of the Avon and is why I think it makes a cracking BEC.
Andy.
room
Fishface
posted on 30/8/05 at 12:49 PM |
Ive nearly finished mine and too be fair ive been fairly happy with it. Ive tried to do a decent job and have accepted that not everything will be
perfect for the money. Certain things have annoyed me and i think that when pat did his he was definately at the new experimental end of it. In
additon he didnt have the dbenefit of a website build diary. I found pats and the other really helpful and thats what ive used as i certainly havent
used the book. Thanks to pats website and moaning i have been able to solve the problems hes had before i got to them (except for unequal wings!,
although you cant see it too much) I think the main gripe is that tiger havent refined the kit after people like pat have raised the problems with it.
All in all im happy so far and i do like the look of a decent finished avon as it certainly looks quite like a caterham.
When im done i would liek to build another and learn from my mistakes and use my new skills to do a better job and i would like to try another kit
manufacturer. The one thing thats saves tiger for sure is the forum and the helpful people on it which wouyld encourage me to do another tiger
model.
So theres my thoughts and if theres one thing i could add is please dont keep slating the avon as its pretty good and i may need to sell in the future
i dont want any more bad press lowering my resale value as i too havent been able to build it for less than 5 grand (8ish is more like it)
Rob
DarrenW
posted on 30/8/05 at 02:13 PM |
try this link.
http://www.mac1motorsports.co.uk/typeZR.htm
Rear suspension is independant. Ive nearly finished my build and it has been a delight to put together. Mac#1 customer service is awesome. You wont
regret it.
Lightning
posted on 4/9/05 at 09:22 PM |
My two peneth
My Avon chassis was great, body not so good, but light.
Mine was under £5k, but I think bike engines are cheaper as they include
carbs etc and generally dont need rebuilding( this could open another can of worms.....again)
I bought the car as it was light and small. which suited the bike engine.
I wish it had seperate rear wings though as the track days take their toll.
