<<  1    2  >>
Author: Subject: all alloy engine
liam.mccaffrey
posted on 29/8/05 at 10:47 AM Reply With Quote
all alloy engine
can anyone think of any other engines which as standard are all ali
apart from
I4 Duratec
K series
RV8
Build Blog
Build Photo Album
Liam
posted on 29/8/05 at 10:59 AM Reply With Quote
Plenty of ally V6s about. Honda, Alfa Romeo, Ford, Mazda, Rover...
liam.mccaffrey
posted on 29/8/05 at 11:07 AM Reply With Quote
i thought that there were alfa v6's that were ali
Rover KV6? isn't it?
nice alloy v6 be good in a seven do you think?
Build Blog
Build Photo Album
posted on 29/8/05 at 11:13 AM Reply With Quote
KV6 in the pre Rover 75 versions were NBG --- even in the 75 and post 2001 Freelander version it has the potential for costing a lot of money to fix.
It is also a lot more complex than the 4 cylinder K16.
[Edited on 29/8/05 by britishtrident]
pathfinder
posted on 29/8/05 at 11:15 AM Reply With Quote
2.5 v6 duratec from a st24/cougar is a nice lump of ali, if its good enough for a noble (with twin turbos added) it should be good enough for a 7.
Liam
posted on 29/8/05 at 11:16 AM Reply With Quote
I was originally going for a KV6 after reading an article in a kit car mag. I joined a rover 800 forum to research it and was told to avoid it and go for the 2.7 honda V6 in pre 96 models. The rest is history...
liam.mccaffrey
posted on 29/8/05 at 11:22 AM Reply With Quote
i thought the kv6 was a bit of a pain but i can't remember why. is it unbalanced or somthing?
Build Blog
Build Photo Album
Liam
posted on 29/8/05 at 11:44 AM Reply With Quote
Um head gaskets mainly I think. Cant quite remember. All sorted now in the latest 75s, but early 800 versions were essentially experimental!
Liam
posted on 29/8/05 at 12:28 PM Reply With Quote
a lot of peugeot engines are all alloy construction, in particular the XU series used in GTis and Mi16s
liam.mccaffrey
posted on 29/8/05 at 12:37 PM Reply With Quote
yes the mi16 i knew that was alloy but i forgot.
thanks guys
Build Blog
Build Photo Album
posted on 29/8/05 at 01:22 PM Reply With Quote
Nissan SR20DE(T)
All alloy and serious power can be had from the turbo'd DET. Also used in the RWD 200SX so a mating gearbox is available.
bimbleuk
posted on 29/8/05 at 01:43 PM Reply With Quote
Toyot engines.
1GZ-FE 5 ltr V12
1UZ-FE 4 ltr V8
3UZ-FE 4.3 ltr V8
1ZZ-FE 1.8 ltr
2ZZ-FE 1.8 ltr
donut
posted on 29/8/05 at 01:45 PM Reply With Quote
How about a nissan Micra???
Don't forget that some of these later engines come with very complicated looms with sensors for just about everything!
gazza285
posted on 29/8/05 at 02:08 PM Reply With Quote
Volvo white block engines.
Alfa four cylinder engines are alloy.
Ford BDG, probably out of your price range that one though.
cosworth
posted on 29/8/05 at 03:02 PM Reply With Quote
Ford Focus/Fiesta 1.6 Zetec SE
posted on 29/8/05 at 03:05 PM Reply With Quote
Got to say it Hillman Limp & Chrysler Sunbeam 930
gazza285
posted on 29/8/05 at 03:10 PM Reply With Quote
Interesting side note. When you put "spares and repairs" into eBay's search function one of the related searches is "Hillman Hunter".
All alloy and rear wheel drive........Reliant Robin.
Volvorsport
posted on 29/8/05 at 03:33 PM Reply With Quote
dont forget the loverly PRV6 - which when the updated B280E came out was fitted in all the alpines with twin turbos .
theres a chap in the us with a volvo 260 rally car with a single T4 turbo updated heads ,forged rods with 600 hp / 600ft/lbs torque - hes also destoyed most of the driveline along with two major excursions on to its roof !!
www.dbsmotorsport.co.uk
getting dirty under a bus
Arthur Dent
posted on 29/8/05 at 08:35 PM Reply With Quote
Suzuki Swift GTi
'The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong, it usually turns out to be impossible to get at or repair.' Douglas Adams
posted on 29/8/05 at 09:59 PM Reply With Quote
Most modern cars are all alloy now... Cast iron is heavy and expensive difficult to machine and a nightmare for COSHH in the UK and Europe. Seems to be ok for Far Eastern countries though...
posted on 29/8/05 at 10:15 PM Reply With Quote
Cast iron is quite nice to machine, though very abrasive so hard on tools.
posted on 29/8/05 at 10:58 PM Reply With Quote
Depends on type - I work on Martensitic and Iron Carbide impregnated - not much fun I assure you. Standard diesel engine blocks - Toyota Yaris - are simple SG which is a POP.
gazza285
posted on 29/8/05 at 11:06 PM Reply With Quote
No mention of any bike engines yet?
madman280
posted on 29/8/05 at 11:52 PM Reply With Quote
I beleive those had an iron block
gazza285
posted on 30/8/05 at 12:04 AM Reply With Quote
The Zetec SE was the Yamaha developed engine and is only available in 1250 and 1700 formats.
<<  1    2  >>
