Author: Subject: Cut The Cat
lenny
posted on 17/9/05 at 04:22 PM Reply With Quote
Cut The Cat
Hi all shoud have gone to Brands this morning ,Droped the wife in to work then set off (8.30 Cardiff) Rear Brake calliper decided to stay on the tin top ,smell of vhot pad and hub so back home and TOOK IT OUT ON THE CAT!!!!!!
lenny
posted on 17/9/05 at 04:23 PM Reply With Quote
So cut it to bits and make it fit
lenny
posted on 17/9/05 at 04:24 PM Reply With Quote
fill the gap
lenny
posted on 17/9/05 at 04:25 PM Reply With Quote
tack in
lenny
posted on 17/9/05 at 04:26 PM Reply With Quote
quick pollish
lenny
posted on 17/9/05 at 04:28 PM Reply With Quote
on ( not for long i hope )
lenny
posted on 17/9/05 at 04:29 PM Reply With Quote
next for the chop
jambojeef
posted on 18/9/05 at 04:45 PM Reply With Quote
Lenny,
You probably know this already but watch out for the contents of your cat! There are all sorts of strange chemcials used in the manufacture apparently and arent all that great if you breathe them in etc!
Sweet bit of welding tho! I removed the contents of my pre-cat on my everyday car and couldnt get the cat casing welded up anywhere near as neatly as that!
Geoff
