robbydee
posted on 20/9/05 at 06:54 PM |
piston info...
have the following figures stamped onto the crown of the pinto piston..therefore are these standard or has the block already been bored?
91.295c SP0.025 LYP
AE21426vi +0.50.
they look in v.good gondition.. with no movement at tdc or bdc, and no lip at the top of the stroke..
Any info please....
Rob D..
posted on 20/9/05 at 07:29 PM |
isnt that a half mm ovrebore? 0.5mm.
91.295 is the bore size i think.
BKLOCO
posted on 20/9/05 at 08:20 PM |
Pinto engines rarely developed a lip at the top of the bore and it was not uncommon to find honing marks still evident on a 100000 miler. Check for a
lip at the bottom of the stroke if you can. This is where the wear will be more evident.
posted on 20/9/05 at 08:31 PM |
It's a .020" rebore.http://www.veloce.co.uk/shop/graphics/pdf/V278.pdf
