Author: Subject: Brake Lock Tabs
richyo
posted on 22/9/05 at 12:26 PM Reply With Quote
Brake Lock Tabs
I know this has been discussed before and that the hub to disc bolts require lock tabs (Cortina) but I was watching an MG is born or re-born or whatever on Discovery and shaw Evans use lock tabs on his calipers.
Does any one know if this is required?
Richyo
marshall
posted on 22/9/05 at 02:13 PM Reply With Quote
i think they are. As ford would not put them on for nothing mine were allrady on there when i got mine so i think you should put some on hope it helps
richyo
posted on 22/9/05 at 02:32 PM Reply With Quote
Mine were so corroded they just looked like washers
Stu16v
posted on 22/9/05 at 05:45 PM Reply With Quote
Ford also fit disc shields as standard, but most folk bin them...
You *could* get rid of the lock tabs...as long as you have another satisfactory way of ensuring that the bolts are not going to loosen.
NS Dev
posted on 23/9/05 at 08:04 AM Reply With Quote
Ford used them on the Cortina, Vauxhall/Opel never did on the chevette/manta/ascona/cavalier/monza/mk1 senator/commodore/rekord etc etc etc all of which used the same tye of setup as the cortina........................................................who was "right"?
Discs and calipers never seemed to fall off either car!!
