jecuk
posted on 27/9/05 at 10:55 PM |
Expanding Foam Race Seat
I have searched and I see several trhreads talking about links to a description of the best procedures for doing a race seat out of expanding foam. I
can't however see any actual links.
Are there a couple of descriptions or DIY guides to doing this in the best way possible?
Thanks.
[Edited on 27/9/05 by jecuk]
andylancaster3000
posted on 27/9/05 at 11:34 PM |
I haven't got the link to any site but I know of a couple of ways of doing them. The first is a two part mix which you put into a bag and sit in
or you can use a couple of cans from b+q. I think both would require some sort of frame to give it some strength.
When we've made them we made the rough shape from a ply construction, then put on a bin bag and sat in it and filled the remaining space with
epanding foam. Then cover it with what ever takes your fancy. Gaffer tape, carpet underlay etc...
Dillinger1977
posted on 28/9/05 at 07:17 AM |
theres a guide in PPC magazine as part of their fury build.
something along the lines of using a binbag, filled with expanding foam, and letting it set a little bit so its a little bit firm.
then sit in it, but hang on to something so its not all your weight on the foam (which would squeeze it all out.)
i'll try and scan it in later on. (or maybe someone else can if theyve got it)
-Rog
jecuk
posted on 28/9/05 at 09:29 AM |
quote: I think both would require some sort of frame to give it some strength.
Do they really need a frame for strength. So long as the foam seat is secure in the car to expansion sort of locking it in, surely the harness gives
you the security and the foam is just there to hold you comfortably.
[Edited on 28/9/05 by jecuk]
jecuk
posted on 28/9/05 at 09:32 AM |
quote: then sit in it, but hang on to something so its not all your weight on the foam (which would squeeze it all out.)
If you could scan it that would be great. Tips like not sitting fully on it are key as I was wondering why when you sat down it wouldn't just
push all the foam out from under you.
NS Dev
posted on 28/9/05 at 11:04 AM |
when I do my foam seats I plan to use some polyurethane foam sheet (camping matting) in the seat base to help stop the base thinning too much.
Avoneer
posted on 28/9/05 at 11:17 AM |
Try Tim Hoverds site.
There's a link in the "Links" section.
Pat...
MikeR
posted on 28/9/05 at 12:37 PM |
Who gave you that idea then?
Supposidly thick neoprene diving suit material is supposed to be good .... just haven't a clue where i can get some cheap.
chrisf
posted on 28/9/05 at 02:18 PM |
Here you are.
robinbastd
posted on 28/9/05 at 09:58 PM |
I've spoken to the chap(Brian) that runs this firm and he might be able to supply smallish quantities of neoprene.
http://www.techneopro.co.uk/start.html
Hope this helps,
Ian
http://smuttygifts.com/
NS Dev
posted on 29/9/05 at 12:02 PM |
Ahh yes, wondered where the idea came from!!![](/images//smilies/bigsmile.gif)
MikeR
posted on 29/9/05 at 06:23 PM |
same place all your good ideas come from!
Avoneer
posted on 29/9/05 at 10:32 PM |
Any update on scanning the article Dillinger?
Pat...
jecuk
posted on 3/10/05 at 09:31 PM |
In a race car, If the seat is done in place, is there any need to secure it or will it just expand to fill the space and lock itself into the car?
