Kelvin
posted on 21/1/03 at 12:27 PM |
X/Flow oil seperator box (?) removal
Hi All,
I'm pulling bits off the engine to give it a bit of a tart up.
I've got to the oil seperator box ((?) rubber pipe from box to carb breather system) on the off side rear and it's a pig! I've undone the bolt but
it still wont shift very far.
has anyone else discovered a succesful technique to removing these, or has anyone got a spare for when I get annoyed with it tommorrow and destroy
it!!
kelvin
wicket
posted on 21/1/03 at 12:56 PM |
IIRC its a push fit into the crank case with an O-ring seal; mine was also rather tight but with a bit of gentle persuasion and some WD40 it came
free.
O/T I am well pleased with the wheels.
Eric
Kelvin
posted on 21/1/03 at 12:58 PM |
Hi Eric,
Cheers for that.
I'll give a squirt before I gove it the hammer then!!
Glad the wheels are okay
kelvin
jollygreengiant
posted on 21/1/03 at 02:16 PM |
rotate mainbody outwards as far as posible then pursuade gently out. Recommend new 'O' ring when refiting.
Enjoy.
darren(SA)
posted on 21/1/03 at 06:24 PM |
Can somebody give me some more info on the oil seperator, briefly how it works and what the point of it is?
My engine is running but I haven't connected that pipe up anywhere yet, where should it go?
I've got twin 40's if it makes any difference
thanks
darren![](/images//smilies/bigsmile.gif)
jollygreengiant
posted on 21/1/03 at 08:10 PM |
Part of crank case ventilation system.
Think this way & you will understand. Your engine sucks air in through the carbs and out through the exhaust. Each piston sucks & blows. EACH PISTON
has TWO faces, A TOP AND A BOTTOM. What happens up top also happens to a lesser degree below, plus ring blow by. Therefore the bottom of the engine
needs to 'breath' usually in through the top (oil filler cap) & out through the bottom ( crank case breather). the breather is not only a trap to
collect oil droplets and allow drainage back to the sump, but also to direct through manifold vaccuum, oil vapours to be burnt through recirculation.
The trouble is that, you can't vent to the inlet manifold on a multi carb set up like twin 40's because the cylinder will draw from the crank case
rather than the carb. So your choices are fit an inlet filter box and vent to that, or Fit a oil collector bottle some where on the bulkhead with a
little air filter ( a small plastic inline fuel filter would do).
I hope this answers your queery.
Enjoy.
Stu16v
posted on 21/1/03 at 08:12 PM |
This is how I plumbed mine up......
The pipe from the oil separator was fed into the rocker cover. Another pipe was attached from the rocker cover into a catch tank. Do not be tempted to
feed the oil separator straight to the catch tank, as under hard acceleration, oil is forced to the back of the block, up the breather, and into the
catch tank, which will be full in no time! It may mean welding one or even two pipes to the rocker cover, but IMO worth the effort. Xflows are a bit
notorious for lack of oil retention anyway, so anything you can do to improve the situation has got to be good.
jollygreengiant
posted on 21/1/03 at 08:25 PM |
or if you are going that route,---- ford fitted a filler breather cap to a fiesta I believe with two or three pipe connectors on it. Just buy one of
those & blank of the pipes not required. JD Change from a fiver no welding.
Enjoy.
[Edited on 21/1/03 by jollygreengiant]
darren(SA)
posted on 22/1/03 at 05:49 PM |
thanks guys, I'll look at the Fiesta's filler cap, only problem is I only know 1 type of fiesta in South Africa
I might just weld the 2 pipes into the rocker cover. doing it this way, I can keep it nice and neat by running all the pipes at the back side of my
engine.
thanks 4 the explanation jollygreengiant
cheers
darren
locodude
posted on 22/1/03 at 10:16 PM |
There's no way the Fiesta cap will fit under a Locost bonnet, it's huge. The method described by Stu is the way to go. I did it the other way first
(crank and rocker box to tank) but like he said it threw out too much. The second way is the way to go, seperator (or alloy adaptor) to rocker cover
and rocker cover to tank. You'll still get some oil in the catch tank but nowhere near as much. I think there may be some pics on my website.
http://www.christopher.gibbons.btinternet.co.uk/Aug022.jpg
[Edited on 22/1/03 by locodude]
darren(SA)
posted on 23/1/03 at 08:03 PM |
I'll definately go that route. Is there any reason why the pipe goes into the cover near the front of the engine and comes out near the back? Or is
this just how that ally cover comes?
Chris, please can you explain your water fill up unit you have fitted. Looks like the top pipe goes into the head and the bottom hole goes to the
water pump? At the moment, I have a pipe fitted between the head & water pump. Is this where I should fit the filler bottle? will this be suffice to
keep my level up? looks like a good idea!
thanks
darren
![](http://www.christopher.gibbons.btinternet.co.uk/Aug022.jpg)
darren(SA)
posted on 23/1/03 at 08:11 PM |
P.S sorry Kelvin for Hijacking your post
Chris, what is that black box next to your battery where the oil overflow pipes go? This can't be the overflow tank or could it?
Ah, the 'black box' as used in Aircrafts, to record your last motions
thanks
darren
[Edited on 23/1/03 by darren(SA)]
locodude
posted on 23/1/03 at 10:10 PM |
Hi darren
The ally cover has a point on the back to accept a tapped hole. The pipe at the front was just a convenient space.
As for the header tank, it is basically there just to provide a convenient point for filling etc as it is the highest point in the system. Strictly
speaking it's not a header tank system as the bottle doesn't have a pipe to the bottom hose to the rad but takes the place of the heater in the
circuit. The return from the tank goes to the water pump. I have to say that it works a treat though. Sat in traffic in france last year in 90deg heat
and no bother whatsoever.
As for the 'black box', yes it's the oil catch tank, guess what it's made of. Plastic of course!
darren(SA)
posted on 23/1/03 at 10:21 PM |
I like this idea,
thanks
darren
ps the 'black box' looks neat
Gizmo
posted on 23/2/03 at 11:03 PM |
The filler cap from the ford V6 has a single outlet pipe from it and is nice and low. Available at Halfrauds.
---john---
davef
posted on 3/3/03 at 10:47 AM |
Hi Guys, i am going the same route as stu & ptm re crankcase breather. what i need to know is should i remove the non return valve from the pipe
coming from the seperator to rocker box, as it is no longer under vacuum? cheers davef.![](/images//smilies/cool.gif)
kingr
posted on 3/3/03 at 12:23 PM |
Hmmm, I'm confused, I assume the connection from the crank case you're talking about is the one just above the fuel pump, however on my engine this
is sealed off with a cap. Any ideas what's going on? In case you didn't already know, my engine is from an XR2 Mk1.
Kingr
Stu16v
posted on 3/3/03 at 05:56 PM |
Davef, yes I removed it as it is really an anti-backfire valve, which is only needed if it plumbed into it's original destination i.e the inlet
manifold.
Kingr, the XR2 system probably does all it's breathing from the rocker cover/filler cap, due to it's original transverse installation. I would look
at getting a breather back in there, as with older designed engines, every little helps...
HTH Stu.
paulf
posted on 3/3/03 at 10:04 PM |
My 1600 crossflow had been adapted to use in a FWD car and the breather hole was blanked off, however the filler cap was a mk4 escort one and has
three pipes coming out of it and is very tall. this was connected to the inlet manifold.
I got an orignal breather box and fitted but have found that if i suck on the pipe it is completly unrestricted from the crankcase, therefore if
conected i would have no manifold vacuum.I think i am going to use a catch tank and connect through the rocker cover as discused.
Now i need to find a nice alloy tank of 1 to 2 litres cappacity that is not to expensive, any ideas?or do i use a plastic rad header type tank.
Paul.
Kingr
Stu16v
posted on 4/3/03 at 10:51 PM |
If planning to do track days/competition with your car check if a minimum size is required but a cycling water bottle from Halfrauds makes a nice ali
catch tank.
HTh Stu.
