Author: Subject: R1 98/99 Speed/Tach wires
jimmy_nugget
posted on 28/9/05 at 11:27 PM Reply With Quote
Hi there,
can someone tell me please what would be the best wires to use for picking up a signal for speed and tach?
Jimmy
progers
posted on 29/9/05 at 01:45 PM Reply With Quote
You don't mention what instruments you want to use.
The most reliable point to pick up the tacho feed is from the low voltage side of the coils. The tacho output from the ECU is not easy to use.
For the speedo its common to have a separate sensor that is trigured by magnets attached to the wheel or propshaft. The speedo feed from the ECU is really only compatible with the bike clocks.
Paul
jimmy_nugget
posted on 29/9/05 at 09:36 PM Reply With Quote
thanks for the help, think ive sorted it now anyway :-)
Jimmy
